Discuss
washer not spinning
 in
Washer Repair
Thanks in advance for all advice....... This is on "Normal cycle" The washer will go through the cycles
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer not spinning
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 05-10-2008, 12:43 PM
golfman golfman is offline
Junior Member
golfman is on a distinguished road
Default washer not spinning
Model Number: lsq9244eq0   Brand: Whirlpool   Age: 5 - 10 years
The washer will go through the cycles fine but when it get to draining it'll drain without spinning and won't spin in the final spin cycle. It will spin if I catch it in time and open/close the lid. It seems to reset itself. I also can get it to spin if I manually push the knob in and turn it to spin and pull out the knob.
I am thinking the timer but it is $100 and would like a second opinion before I just replace parts.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-10-2008, 12:52 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
if its draining then it seems lid switch is ok. by the way your describing it ,could be timer
__________________
  #3 (permalink)
Old 05-10-2008, 01:02 PM
Junior Member
Default
Yes, it is draining fine.
  #4 (permalink)
Old 05-10-2008, 06:27 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
I agree with misterfixall. Most likely the problem is a bad timer.
- The part number for the timer is AP3019781
Here are the break down diagrams for the Whirlpool washer Model LSQ9244EQ0
__________________
Professional appliance repair services in Orange County, California.
  #5 (permalink)
Old 05-10-2008, 06:36 PM
Junior Member
Default
thanks, I will try the part.
  #6 (permalink)
Old 05-10-2008, 06:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep us posted, please.
__________________
  #7 (permalink)
Old 05-14-2008, 12:59 PM
Junior Member
Default
The timer did not work. Same problem
Basically it works fine but I have to be there when I wash. When the soapy water drains and the rinse water drains I need to lift the lid and close it to reset it. Then it will spin otherwise it will not. Any other suggestions? Other than that everything is fine.......
  #8 (permalink)
Old 05-14-2008, 03:00 PM
Senior Expert
APP Volunteer
Default
you are describing a lid switch problem. but in one of your previous letters you said it was draining, are you sure about that? because as far as i know this model cannot drain or spin if lid switch is defective, we only have your word to go by, so please recheck, thanks
__________________
  #9 (permalink)
Old 05-14-2008, 03:07 PM
Junior Member
Default
It drains fine and I still wash clothes in it. I just have to be paying attention to it. As soon as I hear it draining I open it and it is not spinning. When I close it I can hear the tub start spinning. Sometimes I put something in the lid switch and watch it to make sure it's at full speed, which it is.
If it is the lid switch, do I have to take the cabinet off?
Thanks.
  #10 (permalink)
Old 05-14-2008, 03:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Due to your washer has a neutral drain transmission, it should stop for a few seconds during the drain to engage the spin. This stop interval operates by timer, that's why the timer has to be replaced.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer not spinning mariner Washer Repair 5 01-26-2008 04:59 PM
Washer will agitate, but needs help spinning. redi Washer Repair 1 12-14-2007 04:56 PM
washer not spinning rtzjackson Washer Repair 1 12-04-2007 07:22 PM
GE Washer: Not spinning or draining Vonnie2 Washer Repair 0 11-10-2007 09:54 PM
washer timer / not spinning pbush412 Washer Repair 0 09-05-2007 10:32 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
