Discuss
washer not spinning
 in
Washer Repair
I just replace the timer and the problem is still there. the connections also looked good. Would there be any
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer not spinning
  #11 (permalink)
Old 05-14-2008, 04:25 PM
golfman golfman is offline
Junior Member
golfman is on a distinguished road
Default
I just replace the timer and the problem is still there. the connections also looked good. Would there be any bad connections that could cause this??
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 05-14-2008, 05:23 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
but Gene ,he said he replaced timer.
__________________
  #13 (permalink)
Old 05-14-2008, 05:31 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
I would not be surprised if the new timer is defective. Unfortunately I can see it more and more often.
__________________
Professional appliance repair in Los Angeles, California.
  #14 (permalink)
Old 05-14-2008, 05:36 PM
Junior Member
Default
hmmmmmmmm. The brand is FSP and is the same brand I took out. I'm not sure if they'll buy that story at the part place........
  #15 (permalink)
Old 05-15-2008, 04:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
They must!
If you'll search this forum - you can find many times when people had exchange their new parts and it solved problems.
__________________
  #16 (permalink)
Old 05-15-2008, 04:35 PM
Junior Member
Default
Thanks, but is there any possible way it could be the lid switch acting up?
  #17 (permalink)
Old 05-15-2008, 04:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It will never drain if the lid switch is bad.
__________________
  #18 (permalink)
Old 05-16-2008, 10:44 AM
Junior Member
Default
It seems to spin now...............
I tried it on small load and it didn't spin.
Then I washed clothes in it on large load and it does.
I appreciate all the help. I got these for free and they are in good shape. I didn't want to spend $700 and new equipment when cleaning them up and $150 in supply lines/drain hose/timer will get me hopefully a year or two.
Thanks again guys......
  #19 (permalink)
Old 05-16-2008, 03:24 PM
stephen r stephen r is offline
Junior Member
stephen r is on a distinguished road
Default ge won't drain or spin
i bypassed the lid switch and it still didn,t work.it did agetate so i thought it was the timer .now with the new timer it doesnt do a thing .i have power what else could it be ?.could use all the help i could get. thanks
  #20 (permalink)
Old 05-16-2008, 04:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Stephen,
Can you be more specific on the problem?
What is the complete model number of the washer?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer not spinning rtzjackson Washer Repair 3 09-13-2008 09:24 AM
Washer not spinning mariner Washer Repair 5 01-26-2008 05:59 PM
Washer will agitate, but needs help spinning. redi Washer Repair 1 12-14-2007 05:56 PM
GE Washer: Not spinning or draining Vonnie2 Washer Repair 0 11-10-2007 10:54 PM
washer timer / not spinning pbush412 Washer Repair 0 09-05-2007 11:32 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
