| » water level |
Model Number: wsm2780dbwww Brand: GE Age: 5 - 10 years
water does not turn off, just keeps filling up and eventually leaks on to floor.
what part automatically shuts water off when it reaches correct level? Ads By Google Related Models |
Replacement parts for General Electric WSM2780DBWWW Washer dryer combination | AppliancePartsPros.com Water is shut off by the Switch, water Level Item 1105 in Section 1 This switch is actually a pressure switch. It has a tube that runs down to the bottom of the tub, as water fills the tub, air is trapped in the tube. As the water rises, the air pressure in the tube increases until it reaches the switch's set point then the switch activates turning off the water and starting the agitate. Possible problems. 1. Gunk blocking water from entering the tube. Remove the tube at the switch and blow into it to clear the plug. 2. Cracks or holes in the tube allowing the air to escape. Inspect the tube. Also check that it is tight on the switch, if not, cut off half an inch and re-seat it. 3. The switch is toast. Get a piece of tubing with the same internal diameter and attach this to the switch. Start a fill, then blow into the tube. You should be able to stop the water flow without blowing very hard. If you cannot stop it the switch is toast. Note: I am assuming that you can stop the water flow by unplugging or turning off the unit. If the only way to stop it is to shut off the taps your water valve is shot.
__________________
| Display Modes | |
| Water Level | Jerry Gebhart | Dishwasher Repair | 0 | 01-06-2010 02:17 PM |
| Low water level | bassman23601 | Dishwasher Repair | 0 | 11-13-2009 10:26 AM |
| Water level does not shut off/ and it fills with water & drains but does not agitate | dogwood100 | Washer Repair | 1 | 04-14-2009 05:20 PM |
| Low water level | 67shelby | Dishwasher Repair | 7 | 07-12-2008 01:17 PM |
| What should the water level be | flyer903 | Washer Repair | 0 | 12-27-2007 05:06 PM |
