Discuss
Remove Cabinet Kenmore Washer Mod. 110-15942401
 in
Washer Repair
I believe my pump is leaking and went to replace but I am having a heck of a time figuring
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Remove Cabinet Kenmore Washer Mod. 110-15942401
  #1 (permalink)
Old 05-07-2008, 06:39 PM
Junior Member
Jake12 is on a distinguished road
Default Remove Cabinet Kenmore Washer Mod. 110-15942401
Model Number: 110-15942401   Brand: Kenmore   Age: 1 - 5 years
I believe my pump is leaking and went to replace but I am having a heck of a time figuring out how to get the cabinet (outer cover) off. I've reviewed many of these threads and they talk about the screws on control console and or they may be hidden behind plastic covers. I have neither on this machine. Is it a newer model with a different set up to remove the cabinet? I've tried everything I can see without starting to break things. There do appear to be some plastic hinges on the back side that seem to hold the panel but I can't see how to get that panel loose. Is that the first step in repairing a pump on this model??
Thanks,
Scott
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 05-07-2008, 07:55 PM
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
if its the newer style there are no screws to lift up control panel.there are hidden clips under panel on left +right side, i use aputty knife to push +lift. a real pain. then there is brass coloured long clips to be pulled up with screwdriver under clips .then remove wire harness, +pull shell forward +off. feel under pump to see if it wet, that means leak +replace pump
__________________
  #3 (permalink)
Old 05-07-2008, 09:22 PM
Junior Member
Default
Mister Fixall,
Thanks a bunch, that was the trick. Actually the putty knife under the sides worked fairly easy once I knew where to pry it up at. I had tried that earlier but it sure seemed like something was going to break.
I got the pump on and looks like everything is set to go. I decided to hook up the water in the AM and will test out my work then. If all checks out I should be good to go.
This site is awesome. I was ready to give up and call a repair man in the AM but once you got me going it only took a few minutes to change things out. Also thanks for the quick response.
Thanks again
  #4 (permalink)
Old 05-08-2008, 07:05 AM
Junior Member
Default
Works great, thanks again for helping me out and making it a simple fix. Can't believe the pump went out in only 3 years but I guess that is another story.
  #5 (permalink)
Old 05-08-2008, 09:09 AM
Junior Member
Default
See attached picture for detail of console and clip to pry with putty knife. One on left and right side.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing cabinet from Kenmore washer bingo9294 Washer Repair 1 10-27-2009 03:45 PM
How to remove the casing for Kenmore 70 series Washer clair Washer Repair 1 09-22-2009 06:58 PM
Kenmore cabinet ice maker Ken Higgins Refrigerator & Freezer Repair 1 07-29-2009 02:34 PM
remove cabinet tforgey Dryer Repair 2 07-03-2009 05:13 AM
How do I Remove cabinet to get to pump edmgriffin Washer Repair 1 04-13-2009 08:06 AM
