Discuss
Kenmore Front Load Washer Won't Run
 in
Washer Repair
I've suspected for a couple weeks that the spin cycle has been weak (clothes seem a little heavier than usual).
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Front Load Washer Won't Run
  #1 (permalink)
Old 02-09-2010, 07:11 AM
Junior Member
nsmslf4 is on a distinguished road
Default Kenmore Front Load Washer Won't Run
Model Number: 48102   Brand: Kenmore   Age: Less than 1 year
I've suspected for a couple weeks that the spin cycle has been weak (clothes seem a little heavier than usual). This past weekend it made a high grinding noise while spinning and emitted a burnt rubber smell. I removed some clothes and it completed the cycle normally. Next load of wash, upon starting washer, a high buzzing noise was coming from the water pump. Would not spin (don't know if it drained but considering little amount of water at bottom of tub when I removed unspun clothes I'm guessing it did). Unplugged and let it sit for a day. Yesterday, when pressing the 'start' button there is a click and a itty bitty amount of water goes into tub (lasts about a second), then the washer automatically switches the spin speed from high to 'no spin' and doesn't do anything else (although the lights stay on on the display). Checked the belt, it appears fine (on track and not loose).
Has anyone had this problem with a washer? We're not sure if we should try replacing the pump or if it could be something more. Thanks.
Ads By Google
Related Models
Jenn-Air 4855 Range - F/s Std Ddraft Ele
Jenn-Air 4860 Range - F/s Std Ddraft Ele
Jenn-Air 4870 Range - F/s Std Ddraft Ele
Jenn-Air 4875 Range - F/s Std Ddraft Ele
Jenn-Air 4875S
Jenn-Air 4890 Range - F/s Std Ddraft Ele
Frigidaire 49-2151-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2151-00-02 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2151-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2151-23-02 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2251-00-01 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2251-00-02 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2251-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2251-00-04 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2251-23-01 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2251-23-02 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2251-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2251-23-04 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2351-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2351-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2451-00-01 Tap(v5) / 27 " Gas Dryer
Frigidaire 49-2451-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2451-23-01 Tap(v6) / 27 " Gas Dryer
Frigidaire 49-2451-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2551-00-01 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2551-00-03 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2551-23-01 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2551-23-03 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2707-00-01 Tap(v2)
Frigidaire 49-2707-23-01 Tap(v1)
Frigidaire 49-2751-00-01 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2751-00-02 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2751-23-01 Tap(v2) / 27 " Gas Dryer
Frigidaire 49-2827-00-01 Tap(v1) / Gas Dryer
Frigidaire 49-2827-23-01 Tap(v2) / Gas Dryer
Frigidaire 49-2828-00-01 Tap(v3) / Gas Dryer
Frigidaire 49-2828-00-03 Tap(v3) / Gas Dryer
Frigidaire 49-2828-00-04 Tap(v3) / 27 " Gas Dryer
Frigidaire 49-2828-23-01 Tap(v4) / Gas Dryer
Frigidaire 49-2828-23-02 Tap(v2) / Gas Dryer
Frigidaire 49-2828-23-03 Tap(v4) / Gas Dryer
Frigidaire 49-2828-23-04 Tap(v4) / 27 " Gas Dryer
Frigidaire 49-2847-00-01 Tap(v3) / Gas Dryer
Frigidaire 49-2847-23-01 Tap(v4) / Gas Dryer
Frigidaire 49-2848-00-01 Tap(v1) / Gas Dryer
Frigidaire 49-2848-00-02 Tap(v1) / Gas Dryer
Frigidaire 49-2848-00-03 Tap(v1) / Gas Dryer
Frigidaire 49-2848-00-04 Tap(v1) / 27 " Gas Dryer
Frigidaire 49-2848-23-01 Tap(v2) / Gas Dryer
Frigidaire 49-2848-23-03 Tap(v2) / Gas Dryer
Frigidaire 49-2848-23-04 Tap(v2) / 27 " Gas Dryer
Jenn-Air 4900 Range - F/s Std Ddraft Ele
Hoover 49811001 Frigidaire/refrigerator
Whirlpool 4ACE07LD0
Whirlpool 4ACE23LD0
Whirlpool 4AD50DSL1 Dehumidifier
Whirlpool 4AD50J0
Whirlpool 4C
Whirlpool 4CA2762XWG0
Whirlpool 4CA2762XWN0
Whirlpool 4CA2762XWW0
Whirlpool 4CA2782XYG0
Whirlpool 4CA2782XYN0
Whirlpool 4CA2782XYW0
Whirlpool 4CACM07DD0
Whirlpool 4CACM10DD0
Whirlpool 4CACM12DD0
Whirlpool 4CACM12ND0
Whirlpool 4CACM14DD0
Whirlpool 4CACM14ND0
Whirlpool 4CACM18DD0
Whirlpool 4CACM18ND0
Whirlpool 4CACM23DD1
Whirlpool 4CACM23ND1
Whirlpool 4ECKMF87
Whirlpool 4ED20ZKIFN00
Whirlpool 4ED20ZKIFN01
Whirlpool 4ED20ZKIFW00
Whirlpool 4ED20ZKIFW01
Whirlpool 4ED20ZKXBN00
Whirlpool 4ED20ZKXBW00
Whirlpool 4ED20ZKXDN00
Whirlpool 4ED20ZKXDN01
Whirlpool 4ED20ZKXDN02
Whirlpool 4ED20ZKXDW00
Whirlpool 4ED20ZKXDW01
Whirlpool 4ED20ZKXDW02
Whirlpool 4ED20ZKXFN00
Whirlpool 4ED20ZKXFW00
Whirlpool 4ED22DWXTF00
Whirlpool 4ED22DWXTG00
Whirlpool 4ED22DWXTM00
Whirlpool 4ED22DWXTN00
Whirlpool 4ED22DWXTN01
Whirlpool 4ED22DWXTW00
Whirlpool 4ED25DQXAN00
Whirlpool 4ED25DQXAW00
Whirlpool 4ED25DQXBN00
Whirlpool 4ED25DQXBW00
Whirlpool 4ED25DQXDN00
Whirlpool 4ED25DQXDN01
Whirlpool 4ED25DQXDN02
Whirlpool 4ED25DQXDW00
Whirlpool 4ED25DQXDW01
Whirlpool 4ED25DQXDW02
Whirlpool 4ED25DQXFN00
Whirlpool 4ED25DQXFN01
Whirlpool 4ED25DQXFW00
Whirlpool 4ED25DQXFW01
Whirlpool 4ED25DQXVN00
Whirlpool 4ED25DQXVN01
Whirlpool 4ED25DQXVW00
Whirlpool 4ED25DQXVW01
Whirlpool 4ED25PWXWN00
Whirlpool 4ED25PWXWN01
Whirlpool 4ED25PWXWN02
Whirlpool 4ED25PWXWW00
Whirlpool 4ED25PWXWW01
Whirlpool 4ED27DQXBN00
Whirlpool 4ED27DQXBW00
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Front Load Washer HE 4t Ladpol Washer Repair 1 02-14-2010 06:48 AM
Kenmore Front Load Washer 4Ht hvaliquette Washer Repair 1 02-12-2009 03:39 AM
kenmore front load washer mattsea Washer Repair 1 01-11-2009 02:29 PM
Leaky Kenmore Front Load Washer Ericonline Washer Repair 8 01-11-2009 08:33 AM
Kenmore Front Load Washer Vibration Bruce Nevitt Washer Repair 0 12-28-2008 12:37 PM
