| » How to remove the tub |
Model Number: LNC6766A00 Brand: Admiral Age: 5 - 10 years
The washing machine is leaking from under the tub between the transmission and the tub but I cant seam to figure out how to remove the tub.
I have the agatitor (sp) out the bolts at the bottom of the inside tub out, the top of the tub off but i still have the outter tub and the inner tub that are still attached. Can I get to the seals just by removing the inner tub and leave the outter tub still attached w/o having to remove the nuts holding that in place? If so how do i remove the inner tub? I really need to get this machine working as we have been w/o a washing machine for a week now. I have done as much research as possible on the internet for this model and I dont have a manual for this model. Attached you will find a picture of the inside of the tub and the bottom of the tub where the leak is coming from. If you need addtional pictures please let me know and I will try to get a better picture using my dig. cam. This single mother of 5 thanks you in advance. Ads By Google Related Models Last edited by smith972 : 05-03-2008 at 07:28 PM. Reason: To add pictures |
See if this info help. http://www.servicematters.com/maytag...TDL-0086-B.pdf I could not find the service manual off hand, but I should have it someplace. If you need the manual send me a email and I will dig it up for you. AJ
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
| Display Modes | |
| remove top | macnik | Washer Repair | 1 | 09-15-2009 03:22 PM |
| How do I remove the drum? | roryvan | Dryer Repair | 4 | 06-27-2008 05:26 PM |
| Wrench To Remove Nut To Remove Tub | JIMMEER | Washer Repair | 1 | 10-01-2007 04:13 AM |
| Remove the Top | j_lavine | Dryer Repair | 1 | 08-21-2007 07:49 PM |
| Can't remove top | BoyBlue | Dryer Repair | 1 | 08-20-2007 11:49 AM |
