Discuss
Timer ON DRYER NOT RIGHT, TOO FAST
 in
Washer Repair
I Have Changed The Following Parts: Timer, Heater Assembly, Thermal Overload, Bearing Kit And Still The Dryer Isn't Right. When
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Timer ON DRYER NOT RIGHT, TOO FAST
  #1 (permalink)
Old 02-08-2010, 06:59 PM
Junior Member
therealnet is on a distinguished road
Default Timer ON DRYER NOT RIGHT, TOO FAST
Model Number: FEZ831AS1   Brand: Frigidaire   Age: 1 - 5 years
I Have Changed The Following Parts: Timer, Heater Assembly, Thermal Overload, Bearing Kit And Still The Dryer Isn't Right. When I Try To Use The Timed Dry Side, It Runs For 10 Minutes And Turns Off. When I Use The Normal Cycle, It Lasts For 30 Minutes, But It Should Run For An Hour. What Have I Missed? The Only Parts I Can Even Find That Might Be An Issue Are The Following: Thermostat Heater And Thermostat Control. Could They Be The Issue? If So, Which One Or Both? Thanks, My Wife Is Driving Me Crazy About This.
Related Models
Frigidaire FEZ831AS1 Lc - Frigidaire
Frigidaire FEZ831AS2 Frigidaire/laundry Center
Frigidaire FEZ831CFS0 Frigidaire/laundry Center
Frigidaire FEZ831CFS1 LAUNDRY CENTER
Amana FF105 REF - BOTTOM MOUNTS
Amana FF105A REF - BOTTOM MOUNTS
Amana FF105B REF - BOTTOM MOUNTS
Amana FF105L REF - BOTTOM MOUNTS
Amana FF105LA REF - BOTTOM MOUNTS
Amana FF105LB REF - BOTTOM MOUNTS
Amana FF125 REF - BOTTOM MOUNTS
Amana FF125A REF - BOTTOM MOUNTS
Amana FF125B REF - BOTTOM MOUNTS
Amana FF125L REF - BOTTOM MOUNTS
Amana FF125LA REF - BOTTOM MOUNTS
Amana FF125LB REF - BOTTOM MOUNTS
Amana FF15 FREEZER- VERTICAL
General Electric FF16DSARWH Refrigerator
General Electric FF16DSBRWH Refrigerator
General Electric FF16DSCRWH Refrigerator
General Electric FF16DSDRWH Refrigerator
General Electric FF16DSERWH Refrigerator
General Electric FF16DXARWH Refrigerator
General Electric FF16DXBRWH Refrigerator
General Electric FF16DXCRWH Refrigerator
General Electric FF20DSARWH Refrigerator
General Electric FF20DSBRWH Refrigerator
General Electric FF20DSCRWH Refrigerator
General Electric FF20DSDRWH Refrigerator
General Electric FF20DSERWH Freezers
General Electric FF20DXARWH Refrigerator
General Electric FF20DXBRWH Refrigerator
General Electric FF20DXCRWH Refrigerator
Amana FF98 REF - BOTTOM MOUNTS
Amana FF98A REF - BOTTOM MOUNTS
Amana FF98B REF - BOTTOM MOUNTS
Amana FF98L REF - BOTTOM MOUNTS
Amana FF98LA REF - BOTTOM MOUNTS
Amana FF98LB REF - BOTTOM MOUNTS
Frigidaire FFBD1821MB0A DISHWASHER
Frigidaire FFBD1821MS0A DISHWASHER
Frigidaire FFBD1821MW0A DISHWASHER
Frigidaire FFBD2403LB0A DISHWASHER
Frigidaire FFBD2403LB0B DISHWASHER
Frigidaire FFBD2403LS0B DISHWASHER
Frigidaire FFBD2403LW0A DISHWASHER
Frigidaire FFBD2403LW0B DISHWASHER
Frigidaire FFBD2405KB0 DISHWASHER
Frigidaire FFBD2405KB0A DISHWASHER
Frigidaire FFBD2405KS0 DISHWASHER
Frigidaire FFBD2405KS0A DISHWASHER
Frigidaire FFBD2405KW0 DISHWASHER
Frigidaire FFBD2405KW0A DISHWASHER
Frigidaire FFBD2407LB0A DISHWASHER
Frigidaire FFBD2407LB0B DISHWASHER
Frigidaire FFBD2407LM0A DISHWASHER
Frigidaire FFBD2407LM0B DISHWASHER
Frigidaire FFBD2407LQ0A DISHWASHER
Frigidaire FFBD2407LQ0B DISHWASHER
Frigidaire FFBD2407LS0A DISHWASHER
Frigidaire FFBD2407LS0B DISHWASHER
Frigidaire FFBD2407LW0A DISHWASHER
Frigidaire FFBD2407LW0B DISHWASHER
Frigidaire FFBD2409LB0A DISHWASHER
Frigidaire FFBD2409LM0A DISHWASHER
Frigidaire FFBD2409LQ0A DISHWASHER
Frigidaire FFBD2409LS0A DISHWASHER
Frigidaire FFBD2409LW0A DISHWASHER
Frigidaire FFC04M0AW1 Frigidaire/freezer
Frigidaire FFC0513D Frigidaire/freezer
Frigidaire FFC0522DW0 Frigidaire/freezer
Frigidaire FFC0522DW1 Frigidaire/freezer
Frigidaire FFC0522DW10 FREEZER
Frigidaire FFC0522DW11 FREEZER
Frigidaire FFC0522DW12 FREEZER
Frigidaire FFC0522DW13 FREEZER
Frigidaire FFC0522DW14 FREEZER
Frigidaire FFC0522DW15 FREEZER
Frigidaire FFC0522DW16 FREEZER
Frigidaire FFC0522DW17 FREEZER
Frigidaire FFC0522DW18 FREEZER
Frigidaire FFC0522DW19 FREEZER
Frigidaire FFC0522DW2 Frigidaire/freezer
Frigidaire FFC0522DW20 FREEZER
Frigidaire FFC0522DW3 Frigidaire/freezer
Frigidaire FFC0522DW4 Frigidaire/freezer
Frigidaire FFC0522DW5 Frigidaire/freezer
Frigidaire FFC0522DW6 Frigidaire/freezer
Frigidaire FFC0522DW7 FREEZER
Frigidaire FFC0522DW8 FREEZER
Frigidaire FFC0522DW9 FREEZER
Frigidaire FFC0522FW0 Frigidaire/freezer
Frigidaire FFC0522FW1 FREEZER
Frigidaire FFC0522FW2 FREEZER
Frigidaire FFC0522FW3 FREEZER
Frigidaire FFC0522FW4 FREEZER
Frigidaire FFC0522FW5 FREEZER
Frigidaire FFC0522FW6 FREEZER
Frigidaire FFC0522FW7 FREEZER
Frigidaire FFC0522FW8 FREEZER
Frigidaire FFC0522FW9 FREEZER
Frigidaire FFC0522GB0 Frigidaire/freezer
Frigidaire FFC0522GB1 FREEZER
Frigidaire FFC0522GB5 FREEZER
Frigidaire FFC0523DW0 Frigidaire/freezer
Frigidaire FFC0523DW1 Frigidaire/freezer
Frigidaire FFC05C2AW0 Frigidaire/freezer
Frigidaire FFC05C2AW1 Frigidaire/freezer
Frigidaire FFC05C3CW0 Frigidaire/freezer
Frigidaire FFC05C3CW1 Frigidaire/freezer
Frigidaire FFC05C3CW2 Frigidaire/freezer
Frigidaire FFC05C3CW3 Frigidaire/freezer
Frigidaire FFC05C4CW0 Frigidaire/freezer
Frigidaire FFC05K0AW0 Frigidaire/freezer
Frigidaire FFC05K0AW1 Frigidaire/freezer
Frigidaire FFC05K0DW0 Frigidaire/freezer
Frigidaire FFC05K0DW1 Frigidaire/freezer
Frigidaire FFC05K0DW2 Frigidaire/freezer
Frigidaire FFC05K0DW3 Frigidaire/freezer
Frigidaire FFC05K0DW4 Frigidaire/freezer
  #2 (permalink)
Old 02-09-2010, 05:06 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for FRIGIDAIRE FEZ831AS1 Lc - Frigidaire | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodin...134135600e.pdf
And a manual, is fairly general. I am not sure if it is for your exact model.
http://frigidaireservicetips.com/pdfs/488_3.pdf
Please get rid of the capitals at the start of every word, just makes it harder to read.
Only part of the above parts that can shut the unit off is the timer.
You did not say if the timer advances to the off position?
By turning Off, I assume you mean the entire unit re: motor.
Can you turn it back on right away or do you have to wait several minutes.
If you have to wait, this is usually the motor overheating.
I cannot explain why the difference between timed and auto modes.
Doubt either will cause the unit to shut off as neither is in the motor's circuit path.
When running the motor circuit path is:
N neutral, DOOR SWITCH contacts C/NO, MOTOR M6, motor's RUN winding, motor's internal thermal protect, THERMAL LIMITER (fuse), DRYER TIMER contacts C/B, L2
Well at least she has an excuse, mine just drives me crazy.
Need more info on what is happening when it shuts down?
Need info on what you have to do to restart it?
Was this the original problem with the unit?
It does sound like a bad spot in the timer. In timed dry the timer motor gets power all the time, in auto modes it only gets power when the heater is shut off. That would explain the different shut down times.
__________________
  #3 (permalink)
Old 02-09-2010, 11:44 AM
Junior Member
Default
Quote:
Originally Posted by denman View Post
Yes, the timer advanced to the off position and can be turned right back on, not the motor overheating.
The timer will advance 10 minutes, then turn off. You can restart by manually moving the timer and hitting start. There is no motor overheating, as you can restart immediatly after it turns off.
This is the 3rd timer, I figured the same as you, sounded like a timer issue. It's not, can't beleive 3 of them are bad, with exactly the same issue on each of them.
  #4 (permalink)
Old 02-09-2010, 03:38 PM
Senior Expert
APP Volunteer
Default
Weird, weird, weird
That is all I can say
I'm stumped
I am going to put this is the Tech Section perhaps someone else has an idea on what is going on.
__________________
  #5 (permalink)
Old 02-11-2010, 05:13 PM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Does the timer advance to the end of the cycle and does it do the same thing in each cycle?
__________________
  #6 (permalink)
Old 02-12-2010, 06:02 AM
Junior Member
Default fast timer
Quote:
If I set it up on normal dry, it goes completely through the entire cycle, just does it in 1/2 the time it is supposed to( the cycle should be 1 hour and is only 1/2 hour) If I got to timed dry, set it to 80 minutes, it will run for 10 minutes and stop on 70 minutes. I manually advance the timer a little, and it will run for another 10 minutes.
  #7 (permalink)
Old 02-12-2010, 11:04 AM
Senior Expert
APP Volunteer
Default
If you have your original timer, I would compare the gear train the timer motor connects to. You will find your gear train on the new timer is the wrong one. I would just swap the old one to the new timer!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer timer moves to fast igwood Dryer Repair 0 11-28-2009 01:32 PM
Kenmore Dryer Timer not advancing in Auto Dry or Timer Mode but it does heat and dry dspeidel Dryer Repair 6 08-25-2009 03:23 PM
Heat ok - timer turns off to fast jeffpolo Dryer Repair 1 04-30-2009 03:04 PM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 07:40 PM
Maytag Dryer completes cycle fast givemefood Dryer Repair 6 12-10-2008 08:04 PM
