| » washer won't fill for rinse |
Model Number: LWA30AW Brand: Amana Age: More than 10 years
my washer timer stops because it won't fill up for the rinse cycle. It does fill up for the wash cycle.
It does it in all cycles, perm press, delicate, reg. I took the control panel off, but there is no elect. schematic-wiring diagram, nor one in the front panel. Is it the timer contacts, if you think so, how do I get a wiring diagram to check for voltage? Also, I can't get the control knob off to remove the timer. I don't see any lock washer or anything that needs removed to get the timer knob out. Ads By Google Related Models |
If you can get it going by manually advancing the timer, it is probably the timer.
Here is a service manual which has all the info you asked for. http://www.servicematters.com/maytag...S3100005R3.pdf
__________________
Another question...
I ordered a new timer but I can't get the knob off the old one. I see what looks like a small spring clip on the timer end of the knob, but can't figure out how to remove it. Doesn't seem to be anything that I can remove with any tool I have? Any ideas? |
[quote=sidfink43;189276]Push in the timer and unscrew the knob.
Also, please post in normal sized fonts. It looks like you are yelling at us. Thanks for the help. Sorry about the large font, I'm kinda old and have a hard time reading small print. I'd never yell at people taht are giving me such good help! |
| Display Modes | |
| Roper Washer Will Not Fill At Rinse Mode | BrownOctober | Washer Repair | 5 | 04-13-2013 10:16 AM |
| Only on rinse cycle washer won't fill up with water, goes right to the drain hose | pmmcadams | Washer Repair | 1 | 08-10-2009 03:33 PM |
| Washer does not start rinse, will not fill with cold water | Gene51 | Washer Repair | 10 | 06-27-2009 04:09 PM |
| Washer continuously drains w/ water running after rinse fill | HSquare | Washer Repair | 1 | 01-14-2009 06:44 PM |
| washer wont fill or rinse or final spin | Kangasr25 | Washer Repair | 0 | 04-23-2008 07:25 PM |
