Hello Everyone,
I have this front load washer which worked fine until I had to move from original location to pick up something from behind and since almost every time when finishes a wash cycle and needs to dump the water into the wall outlet (wall) part of used water is coming off the wall on the floor making a mess.... I tried to make a chemical treatment of the wall drainage, checking the outlet hose, but it did not helped too much. There are days when works fine and days when is dumping water on every wash cycle. I have to shut off the machine to avoid a mess in the laundry area. After the water drains from inside the pipe outlet I re-start the machine and it runs the cycle from where it left...a pain! Does anyone has any suggestions for this issue?
Thanks a bunch for help, Luc
