Discuss
kenmore washer/
 in
Washer Repair
need to replace the direct drive assembly but don't know how to take motor off / or outside case . when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore washer/
  #1 (permalink)
Old 05-01-2008, 10:10 PM
mdevore mdevore is offline
Junior Member
mdevore is on a distinguished road
Default kenmore washer/
Model Number: 11020722911   Brand: Kenmore   Age: 1 - 5 years
need to replace the direct drive assembly but don't know how to take motor off / or outside case . when lay on side oil comes out any directions thanks morris mdevore@inbox.com
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-02-2008, 03:03 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If the washer was slinging out oil before, you have a bad tranny. Remove panel screws, tilt panel back, remove the spring clips, remove lit switch connector, and remove outer shell. Look at tranny for oil leaking. If so, you have a bad tranny.
__________________
  #3 (permalink)
Old 05-11-2008, 08:26 AM
IWNTMORHP!! IWNTMORHP!! is offline
Junior Member
IWNTMORHP!! is on a distinguished road
Default
it wasn't on mine...i was an idiot and left it on it's side and it drained out...can you refill the transmission? if so how?
  #4 (permalink)
Old 05-11-2008, 11:13 AM
Senior Expert
APP Volunteer
Default
Clamp the tranny in a bench vise, make it level, then take the cover off and re-fill with 90 weight gear oil.
__________________
  #5 (permalink)
Old 05-11-2008, 11:41 AM
Junior Member
Default
thank you very much...i will give it a shot!
  #6 (permalink)
Old 05-11-2008, 05:37 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The part number for the gear case oil is AP3072960
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer oil leak bobtx Washer Repair 3 05-11-2008 07:56 AM
Kenmore washer ebobalik Washer Repair 3 04-19-2008 07:06 PM
kenmore washer DeeWayne Washer Repair 0 03-08-2008 01:19 PM
Kenmore washer Tiffany Washer Repair 1 11-19-2007 02:00 PM
kenmore washer peterman Washer Repair 0 11-15-2007 02:49 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
