Discuss
Kenmore Elite HE3 tub grinding plastic edge
 in
Washer Repair
At the end of a wash cycle today, I heard a loud thumping like the load was WAY off balance.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Elite HE3 tub grinding plastic edge
  #1 (permalink)
Old 02-07-2010, 02:12 PM
Junior Member
txalfa is on a distinguished road
Default Kenmore Elite HE3 tub grinding plastic edge
Model Number: 110.42922200   Brand: Kenmore   Age: 5 - 10 years
At the end of a wash cycle today, I heard a loud thumping like the load was WAY off balance. I went in to stop the spin and see if I could adjust it. There was about 4 mins left on the cycle and when i opened the front door, i noticed small white specs on some of the clothes near the door and the faint odor of burning plastic. On closer inspection, it appears that the tub was grinding the plastic edge of the tub enclosure (see pics). The edge was ground up pretty much all the way around except for a small section from about the 10:00 to the 11:00 positions. Most of the plastic just balled up and adhered to the edge, but some of the plastic frayed off and this is what was on my clothes.
When I try moving the tub up and down, the plastic part seems to move with the tub. When i turn the tub, though, i see that the tub seems to turn on a different axis and I can see where it wobbles closer to the plastic edge. I did have a large load when I noticed this and so I'm assuming that contributed enough to make the tub and plastic edge touch and friction did the rest. What I'm trying to figure out is what this is a symptom of...I did the check for rear bearing (no noise or rough feel when turning, and no thumping when grabbing it at the 12 and 6 and moving in/out/up/down).
Any ideas?
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 02-09-2010, 06:18 AM
Junior Member
Default
bump - anyone know if the tub's rotation can be adjusted?
  #3 (permalink)
Old 02-13-2010, 09:57 AM
Junior Member
Default Bearing or supports?
So I cleared all the loose plastic that was ground off the edge of the front tub assembly, put it back together and now (with a regular size load) the spin cycle is very wobbly. When it reaches the high rpms at the end of the cycle, it starts thumping very loudly.
I tried grabbing the tub and moving it several directions, listening for any noise and there was none. I do not hear any noise when I manually spin the drum, although it does seem to spin off-center.
Does this sound like a bearing problem or perhaps a problem with one (or multiple) shock absorber supports? How can I tell?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dishwasher grinding noise simonboyce Dishwasher Repair 14 01-03-2013 03:30 PM
Replacing plastic water line Kenmore Frig samoore105 Refrigerator & Freezer Repair 2 02-11-2012 06:57 PM
broken plastic around outside edge hjoans Microwave Repair 0 02-14-2009 07:27 PM
Grinding noise-Kenmore Rick08 Dryer Repair 1 05-30-2008 01:17 PM
Kenmore washer has broken plastic piece jordan1957 Washer Repair 2 01-07-2008 10:29 AM
