Discuss
washing machine wont agitate, spin, or drain.
 in
Washer Repair
My washing machine will fill with water, but then will not agitate but only click or humm lightly. it goes
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washing machine wont agitate, spin, or drain.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-30-2008, 02:15 PM
rathresidence rathresidence is offline
Junior Member
rathresidence is on a distinguished road
Default washing machine wont agitate, spin, or drain.
Model Number: LNC676OB71   Brand: Admiral   Age: 1 - 5 years
My washing machine will fill with water, but then will not agitate but only click or humm lightly. it goes throught the cycle though so i think the timer is good. Also before it quit something smelled like it burned. I looked for a fuse but didnt see one. Is the motor bad?
Nate
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 05-01-2008, 03:32 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Nate,
Lift the washer from the front and remove the belt.
Check if the pump is moving freely.
Check if the motor will run without load.
Post your findings.
Here are the break down diagrams for the Admiral washer Model LNC6760A71
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag wont agitate/drain/spin fletch Washer Repair 1 02-09-2008 09:16 PM
Washing machine spin cycle off balance Mike Diven Washer Repair 2 02-05-2008 12:18 AM
Washing Machine Spin Dance mdg Washer Repair 1 01-29-2008 06:09 PM
Washing Machine Won't Agitate cindyw Washer Repair 3 10-18-2007 02:17 AM
Washing machine wont drain dirtyclothes Washer Repair 1 07-23-2007 06:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
