Discuss
water will not shut off
 in
Washer Repair
maytag neptune, water will not stop entering the machine. If you unplug it , it will stop. pressure switch never opens
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water will not shut off
  #1 (permalink)
Old 08-27-2007, 04:16 PM
jim4032 jim4032 is offline
Junior Member
jim4032 is on a distinguished road
Default water will not shut off
Model Number: mah5500aww   Brand: Maytag   Age: 5 - 10 years
maytag neptune, water will not stop entering the machine. If you unplug it , it will stop. pressure switch never opens to advance the cycle. If you blow into it continuity is lost, but when air dome hose is hooked back up it never opens in either wash or rinse.The air dome hose enters the tub underneath and how do you remove it from the machine? If anyone can help me I {and wife} would appreciate it very much.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-01-2007, 03:56 PM
badace badace is offline
Junior Member
badace is on a distinguished road
Default
I have the same issue with the same model. It seems to be the fill valve but I am not certain. It is very hard to access the unit with out removing everything. Any ideas for me too I would greatly appreciate it.
  #3 (permalink)
Old 12-02-2007, 03:34 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You can find complete instructions on how to diagnose and fix your Maytag Neptune washer in the service manual.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
my oven is shut down munequita4u2 Oven Repair (including Ranges and Cooktops) 7 05-29-2008 01:49 PM
Stove will not shut off! mntexn Oven Repair (including Ranges and Cooktops) 0 08-23-2007 11:04 AM
Dryer won't shut off on Cotton or Perm Press wlucas001 Dryer Repair 0 08-12-2007 07:26 PM
Automatic Permanent Press Cycle fails to shut off DECALGUY Dryer Repair 3 08-04-2007 08:28 PM
Element won't shut off Morris Oven Repair (including Ranges and Cooktops) 0 08-01-2007 06:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
