| » Agitator "Ratchets"/moves in counterclokwise direction only |
Model Number: GST9679PW1 Brand: Whirlpool Age: 1 - 5 years
Main bottom agitator moves in one direction ( counterclockwise) only and makes a loud clunk with each stroke. Is there a known issue with the gearcase in this model, gearcase P/N 3360630, AKA GC-215-C? Less than 5 years service in normal household doesn't seem very good to me!!
Quote:
I have the same issue: no or low load agitator works properly...add a bit more load or water and it starts going CCW only. Upper agitator and dogs are fine...this is purely the lower agitator. Reading various places makes me think its the gear box...or maybe the coupler...I am about to tear the machine apart to checkit out |
I have repaired the washer. The original parts provided less than .035 inches of engagement between the agitator gear and shaft splines when "fully engaged" (measured with feeler gage with splines disengaged and cam engaged). A heavy load deformed the splines on the agitator shaft in one direction; they slipped apart on the "push" stroke of the rack but engaged on the pull stroke. The replacement gear/shaft parts provided give spline engagement of approx. .095 inches and include a different part number gear, P/N W10110245 that has more spline on the bottem side. I think either the original parts were defective or the design provided insufficient spline engagement. This gearcase was actually marked as 33606329 instead of 3360630, was made in 2005.
I noticed the coupler was pretty heavily worn....three of the holes were obbed-out. My thought is possibly the slop in the coupler was preventing the gearbox from working properly (i.e. not giving enough throw on one stroke. I am going to replace that and see if things improve. If not...then I guess I will be tearing into the gearbox (was trying to avoid that)...while I am at the store I will also pickup the washer....thanks for the post FCANST2
Just to close out my experience for others: Replacing worn coupler and dogs didnt solve it. Replaced the gearcase with a new unit....Case was faulty (input shaft seal blew out...oil from case drained under my washer [joy]). Replaced gearbox a 2nd time...and that seems to have worked (sample of one load.....will write again if it proves to not be solved...but I think I am done now).
| Display Modes | |
| Timer moves during "timed dry" but not during auto sense | zachunderwood | Dryer Repair | 0 | 01-27-2010 12:02 PM |
| Agitator "dogs" replacement | nickthomas | Washer Repair | 1 | 03-21-2009 07:35 AM |
| Removal/replacement of "dogs" in agitator | PenceP | Washer Repair | 2 | 10-21-2008 09:11 AM |
| "Oven" and "Heating" LEDs blinking | dwartz | Oven Repair (including Ranges and Cooktops) | 1 | 06-23-2008 10:21 PM |
| Agitator makes loud "smashing sound" during spin cycle | Spug | Washer Repair | 3 | 04-06-2008 05:43 PM |
