Discuss
Top loader Washer Agitates, but no spin.. with smoke and burn
 in
Washer Repair
I posted yesterday and the post seems to have evaporated without explanation. My Maytag toploader all of a sudden, in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Top loader Washer Agitates, but no spin.. with smoke and burn
View Poll Results: Where do you think the problem is likely to be?
In the transmission 0 0%
In the tub bearing 0 0%
In the brake release/clutch? 1 100.00%
Somewhere else? 0 0%
Voters: 1. You may not vote on this poll
  #1 (permalink)
Old 02-05-2010, 09:02 PM
Junior Member
Maytagburned is on a distinguished road
Unhappy Top loader Washer Agitates, but no spin.. with smoke and burn
Model Number: LAT9356AAE   Brand: Maytag   Age: 1 - 5 years
I posted yesterday and the post seems to have evaporated without explanation. My Maytag toploader all of a sudden, in a spin and rinse cycle started making a loud shrieking squealing noise, and the laundry room started filling up with smoke. Stopped the washer.. it was partially drained. Took off the belts and the Main Drive belt seemed to be burnt at one spot and glossy in a six inch length. The pump drive belt was fine.. no signs of wear or damage. Put in a new Drive Belt... same effect. Took off the main drive belt and let the pump empty out the water in the spin cycle.
Turned the SPIN cycle on and off by depressing the lid switch. Would hear a small sound (thump) and a tub would shake (attempt to start a rotation without success) and stop. Repeated several times with the same result. Tried to forcibly rotate the tub with the switch off... required a lot of force to get it to move.. almost like the tub was being held by the brakes. No extraordinary noise (like one would expect if a bearing was shot). I am afraid to attack the thing and take things apart pell mell. What is the likeliest source of the problem? What else can I do to diagnose it?
Please respond. Thanks.
Ads By Google
Related Models
Maytag LAT9356AAE Washer - Top Loading
Maytag LAT9356AAM Washer - Top Loading
Maytag LAT9356AAQ Washer - Top Loading
Maytag LAT9356ABE Washer - Top Loading
Maytag LAT9356ABM Washer - Top Loading
Maytag LAT9357AAE Washer - Top Loading
Maytag LAT9357AAM Washer - Top Loading
Maytag LAT9357AAQ Washer - Top Loading
Maytag LAT9360AAE Washer - Top Loading
Maytag LAT9390AAE Washer - Top Loading
Maytag LAT9400AAE Washer - Top Loading
Maytag LAT9400AAL Washer - Top Loading
Maytag LAT9400AAW Washer - Top Loading
Maytag LAT9400ABE Washer - Top Loading
Maytag LAT9400ABL Washer - Top Loading
Maytag LAT9400ABW Washer - Top Loading
Maytag LAT9400AGL Washer - Top Loading
Maytag LAT9400AGW Washer - Top Loading
Maytag LAT9400AGX Washer - Top Loading
Maytag LAT9400DAL Washer - Top Loading
Maytag LAT9400DAW Washer - Top Loading
Maytag LAT9406AAE Washer - Top Loading
Maytag LAT9406AAM Washer - Top Loading
Maytag LAT9406ABE Washer - Top Loading
Maytag LAT9416AAE Washer - Top Loading
Maytag LAT9416AAM Washer - Top Loading
Maytag LAT9416AAQ Washer - Top Loading
Maytag LAT9420AAE Washer - Top Loading
Maytag LAT9457AAE Washer - Top Loading
Maytag LAT9457AAM Washer - Top Loading
Maytag LAT9457AAQ Washer - Top Loading
Maytag LAT9457BAE Washer - Top Loading
Maytag LAT9520AAE Washer - Top Loading
Maytag LAT9520AAQ Washer - Top Loading
Maytag LAT9557AAE Washer - Top Loading
Maytag LAT9557AAM Washer - Top Loading
Maytag LAT9557AAQ Washer - Top Loading
Maytag LAT9593AAL Washer - Top Loading
Maytag LAT9593AAW Washer - Top Loading
Maytag LAT9593ABL Washer - Top Loading
Maytag LAT9593ABW Washer - Top Loading
Maytag LAT9600AAL Washer - Top Loading
Maytag LAT9600AAW Washer - Top Loading
Maytag LAT9600ABL Washer - Top Loading
Maytag LAT9600ABW Washer - Top Loading
Maytag LAT9604AAE Washer - Top Loading
Maytag LAT9604AAL Washer - Top Loading
Maytag LAT9604AAM Washer - Top Loading
Maytag LAT9604ABE Washer - Top Loading
Maytag LAT9604ABL Washer - Top Loading
Maytag LAT9605AAE Washer - Top Loading
Maytag LAT9605AAM Washer - Top Loading
Maytag LAT9606AAE Washer - Top Loading
Maytag LAT9606AAM Washer - Top Loading
Maytag LAT9606ABE Washer - Top Loading
Maytag LAT9606ABM Washer - Top Loading
International LAT9606AGE Washer - Top Loading
International LAT9606BGE Washer - Top Loading
International LAT9606GGE Washer - Top Loading
Maytag LAT9614AAE Washer - Top Loading
Maytag LAT9614AAL Washer - Top Loading
Maytag LAT9614AAM Washer - Top Loading
Maytag LAT9615AAE Washer - Top Loading
Maytag LAT9615AAM Washer - Top Loading
Maytag LAT9616AAE Washer - Top Loading
Maytag LAT9616AAM Washer - Top Loading
Maytag LAT9634AAE Washer - Top Loading
Maytag LAT9634AAL Washer - Top Loading
Maytag LAT9634AAM Washer - Top Loading
Maytag LAT9634ABE Washer - Top Loading
Maytag LAT9635AAE Washer - Top Loading
Maytag LAT9635AAM Washer - Top Loading
Maytag LAT9700AAG Washer - Top Loading
Maytag LAT9700AAL Washer - Top Loading
Maytag LAT9700AAW Washer - Top Loading
Maytag LAT9700AAX Washer - Top Loading
Maytag LAT9700ABL Washer - Top Loading
Maytag LAT9700ABW Washer - Top Loading
Maytag LAT9700DAG Washer - Top Loading
Maytag LAT9700DAL Washer - Top Loading
Maytag LAT9700DAW Washer - Top Loading
Maytag LAT9704AAE Washer - Top Loading
Maytag LAT9704AAL Washer - Top Loading
Maytag LAT9704AAM Washer - Top Loading
Maytag LAT9704ABE Washer - Top Loading
Maytag LAT9704ABL Washer - Top Loading
Maytag LAT9704ABM Washer - Top Loading
International LAT9704AGE Washer - Top Loading
International LAT9704BGE Washer - Top Loading
Maytag LAT9704DAL Washer - Top Loading
Maytag LAT9704DAM Washer - Top Loading
International LAT9704GGE Washer - Top Loading
Maytag LAT9706AAE Washer - Top Loading
Maytag LAT9706AAM Washer - Top Loading
Maytag LAT9706AAQ Washer - Top Loading
Maytag LAT9706ABE Washer - Top Loading
Maytag LAT9714AAE Washer - Top Loading
Maytag LAT9714AAL Washer - Top Loading
Maytag LAT9714AAM Washer - Top Loading
Maytag LAT9734AAE Washer - Top Loading
Maytag LAT9734AAL Washer - Top Loading
Maytag LAT9734AAM Washer - Top Loading
Maytag LAT9734ABE Washer - Top Loading
Maytag LAT9734ABL Washer - Top Loading
Maytag LAT9757AAE Washer - Top Loading
Maytag LAT9757AAM Washer - Top Loading
Maytag LAT9766AAE Washer - Top Loading
Maytag LAT9800AAL Washer - Top Loading
Maytag LAT9800AAW Washer - Top Loading
Maytag LAT9800ABL Washer - Top Loading
Maytag LAT9800ABW Washer - Top Loading
Maytag LAT9800AGL Washer - Top Loading
Maytag LAT9800AGW Washer - Top Loading
Maytag LAT9800AGX Washer - Top Loading
Maytag LAT9804AAE Washer - Top Loading
Maytag LAT9804AAL Washer - Top Loading
Maytag LAT9804AAM Washer - Top Loading
Maytag LAT9804ABE Washer - Top Loading
Maytag LAT9806AAE Washer - Top Loading
Maytag LAT9806AAM Washer - Top Loading
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Top Loader Washer Agitates but doesn't Spin Maytagburned Washer Repair 4 02-10-2010 02:38 PM
washer doesnt spin all i hear is buzzing and the smell of smoke willp3 Washer Repair 8 06-23-2009 01:45 AM
Admrial Washer wont spin and smoke Shawn4455 Washer Repair 1 05-08-2009 05:48 PM
Whirlpool agitates, won't spin burn smell SBMiller Washer Repair 1 12-18-2008 04:31 AM
Stacked Washer/dryer Wont Spin/burn Smell rustknee Washer Repair 2 03-10-2008 05:23 PM
