Discuss
Top Loader Washer Agitates but doesn't Spin
 in
Washer Repair
I came home to the washer running, happily agitating, when it stopped and started the drain and spin cycle. About
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Top Loader Washer Agitates but doesn't Spin
  #1 (permalink)
Old 02-04-2010, 06:50 PM
Junior Member
Maytagburned is on a distinguished road
Default Top Loader Washer Agitates but doesn't Spin
Model Number: LAT9356AAE   Brand: Maytag   Age: 5 - 10 years
I came home to the washer running, happily agitating, when it stopped and started the drain and spin cycle. About 60 seconds into the cycle a high pitched sound started coming, and the smell of burning rubber. Stopped the washer, and assuming that something had happened to the drive belt for the spin, took it off and replaced it. Looking at the belt it seemed to be slightly glazed in a 6" length (probably the part that was slipping on the drive motor pulley. Took the drum drive belt off again, and ran the washer in the spin and rinse cycle to empty out the tub. The pump worked just fine and drained the tub. Put the switch to off, and tried to move the tub... it was very tough to make it move... either the bearing was shot, or the brakes weren't letting go.. didn't know which.
Put the drive belt back on, and ran it in the initial "agitate" cycle, which seemed to work fine. When it switched to the spin cycle I would hear a very small "thud" which must be the brake disengagement mechanism attempting to disengage, I suppose. How do I figure out whether it is the brake that is failing to disengage, or it is a bearing that is shot? I don't want to rip everything apart and find out at the end of hours of work that it was a 10 minute fix , if I had known what I was doing.
Please help!
Thanks.
Ads By Google
Related Models
Maytag LAT9356AAE Washer - Top Loading
Maytag LAT9356AAM Washer - Top Loading
Maytag LAT9356AAQ Washer - Top Loading
Maytag LAT9356ABE Washer - Top Loading
Maytag LAT9356ABM Washer - Top Loading
Maytag LAT9357AAE Washer - Top Loading
Maytag LAT9357AAM Washer - Top Loading
Maytag LAT9357AAQ Washer - Top Loading
Maytag LAT9360AAE Washer - Top Loading
Maytag LAT9390AAE Washer - Top Loading
Maytag LAT9400AAE Washer - Top Loading
Maytag LAT9400AAL Washer - Top Loading
Maytag LAT9400AAW Washer - Top Loading
Maytag LAT9400ABE Washer - Top Loading
Maytag LAT9400ABL Washer - Top Loading
Maytag LAT9400ABW Washer - Top Loading
Maytag LAT9400AGL Washer - Top Loading
Maytag LAT9400AGW Washer - Top Loading
Maytag LAT9400AGX Washer - Top Loading
Maytag LAT9400DAL Washer - Top Loading
Maytag LAT9400DAW Washer - Top Loading
Maytag LAT9406AAE Washer - Top Loading
Maytag LAT9406AAM Washer - Top Loading
Maytag LAT9406ABE Washer - Top Loading
Maytag LAT9416AAE Washer - Top Loading
Maytag LAT9416AAM Washer - Top Loading
Maytag LAT9416AAQ Washer - Top Loading
Maytag LAT9420AAE Washer - Top Loading
Maytag LAT9457AAE Washer - Top Loading
Maytag LAT9457AAM Washer - Top Loading
Maytag LAT9457AAQ Washer - Top Loading
Maytag LAT9457BAE Washer - Top Loading
Maytag LAT9520AAE Washer - Top Loading
Maytag LAT9520AAQ Washer - Top Loading
Maytag LAT9557AAE Washer - Top Loading
Maytag LAT9557AAM Washer - Top Loading
Maytag LAT9557AAQ Washer - Top Loading
Maytag LAT9593AAL Washer - Top Loading
Maytag LAT9593AAW Washer - Top Loading
Maytag LAT9593ABL Washer - Top Loading
Maytag LAT9593ABW Washer - Top Loading
Maytag LAT9600AAL Washer - Top Loading
Maytag LAT9600AAW Washer - Top Loading
Maytag LAT9600ABL Washer - Top Loading
Maytag LAT9600ABW Washer - Top Loading
Maytag LAT9604AAE Washer - Top Loading
Maytag LAT9604AAL Washer - Top Loading
Maytag LAT9604AAM Washer - Top Loading
Maytag LAT9604ABE Washer - Top Loading
Maytag LAT9604ABL Washer - Top Loading
Maytag LAT9605AAE Washer - Top Loading
Maytag LAT9605AAM Washer - Top Loading
Maytag LAT9606AAE Washer - Top Loading
Maytag LAT9606AAM Washer - Top Loading
Maytag LAT9606ABE Washer - Top Loading
Maytag LAT9606ABM Washer - Top Loading
International LAT9606AGE Washer - Top Loading
International LAT9606BGE Washer - Top Loading
International LAT9606GGE Washer - Top Loading
Maytag LAT9614AAE Washer - Top Loading
Maytag LAT9614AAL Washer - Top Loading
Maytag LAT9614AAM Washer - Top Loading
Maytag LAT9615AAE Washer - Top Loading
Maytag LAT9615AAM Washer - Top Loading
Maytag LAT9616AAE Washer - Top Loading
Maytag LAT9616AAM Washer - Top Loading
Maytag LAT9634AAE Washer - Top Loading
Maytag LAT9634AAL Washer - Top Loading
Maytag LAT9634AAM Washer - Top Loading
Maytag LAT9634ABE Washer - Top Loading
Maytag LAT9635AAE Washer - Top Loading
Maytag LAT9635AAM Washer - Top Loading
Maytag LAT9700AAG Washer - Top Loading
Maytag LAT9700AAL Washer - Top Loading
Maytag LAT9700AAW Washer - Top Loading
Maytag LAT9700AAX Washer - Top Loading
Maytag LAT9700ABL Washer - Top Loading
Maytag LAT9700ABW Washer - Top Loading
Maytag LAT9700DAG Washer - Top Loading
Maytag LAT9700DAL Washer - Top Loading
Maytag LAT9700DAW Washer - Top Loading
Maytag LAT9704AAE Washer - Top Loading
Maytag LAT9704AAL Washer - Top Loading
Maytag LAT9704AAM Washer - Top Loading
Maytag LAT9704ABE Washer - Top Loading
Maytag LAT9704ABL Washer - Top Loading
Maytag LAT9704ABM Washer - Top Loading
International LAT9704AGE Washer - Top Loading
International LAT9704BGE Washer - Top Loading
Maytag LAT9704DAL Washer - Top Loading
Maytag LAT9704DAM Washer - Top Loading
International LAT9704GGE Washer - Top Loading
Maytag LAT9706AAE Washer - Top Loading
Maytag LAT9706AAM Washer - Top Loading
Maytag LAT9706AAQ Washer - Top Loading
Maytag LAT9706ABE Washer - Top Loading
Maytag LAT9714AAE Washer - Top Loading
Maytag LAT9714AAL Washer - Top Loading
Maytag LAT9714AAM Washer - Top Loading
Maytag LAT9734AAE Washer - Top Loading
Maytag LAT9734AAL Washer - Top Loading
Maytag LAT9734AAM Washer - Top Loading
Maytag LAT9734ABE Washer - Top Loading
Maytag LAT9734ABL Washer - Top Loading
Maytag LAT9757AAE Washer - Top Loading
Maytag LAT9757AAM Washer - Top Loading
Maytag LAT9766AAE Washer - Top Loading
Maytag LAT9800AAL Washer - Top Loading
Maytag LAT9800AAW Washer - Top Loading
Maytag LAT9800ABL Washer - Top Loading
Maytag LAT9800ABW Washer - Top Loading
Maytag LAT9800AGL Washer - Top Loading
Maytag LAT9800AGW Washer - Top Loading
Maytag LAT9800AGX Washer - Top Loading
Maytag LAT9804AAE Washer - Top Loading
Maytag LAT9804AAL Washer - Top Loading
Maytag LAT9804AAM Washer - Top Loading
Maytag LAT9804ABE Washer - Top Loading
Maytag LAT9806AAE Washer - Top Loading
Maytag LAT9806AAM Washer - Top Loading
  #2 (permalink)
Old 02-06-2010, 05:10 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
There is no 10 minute fix and you are going to have to rip into it and check the brakes.
You will need a special tool and the service manual. Here is the manual,
http://www.servicematters.com/maytag...(16001145).pdf
__________________
  #3 (permalink)
Old 02-06-2010, 10:18 PM
Junior Member
Default
Thanks. I've gotten to the part of removing the drive belts, and taking off the pulley. I've taken the hexbolt and the retaining clip out of the brake assembly... but for the life of me I cannot make the brake assembly budge! There's nothing in the manual about whether one unscrews it or hammers the damn thing out... guidance please???? ... before I hurt myself or the machine !!!
  #4 (permalink)
Old 02-07-2010, 06:25 AM
Senior Expert
APP Volunteer
Default
If you do not have the special brake removal tool, then STOP!
Get one and then follow the instructions in the manual. This can be dangerous work so if you are at all uncertain do not continue but get a qualified repair tech out.
__________________
  #5 (permalink)
Old 02-10-2010, 02:38 PM
Junior Member
Default
Thanks for the final advice. I hammer&chiseled off the brake assembly.. which the Appliance Parts guy had also said was the problem. Turns out, it wasn't... and I unnecessarily destroyed a perfectly fine drum assembly. The problem really turned out to be a corroded tub-bearing.. for which I hired an experienced appliance service tech to do the job. What amazes me is the lack of insight of all the "experienced" guys I dealt with... even the appliance tech.. who removed and replaced a grungy part because he claimed it was bad and replaced it. I checked the grungy part and it was not functioning.. but ater 5 minutes of cleaning, I re-checked it, and it was perfectly fine! Needless to say, the whole experience set me back a ton of money... next time, I'm throwing the sucker into the landfill and just getting a solid European washer. A couple of hundred bucks more, and I could have bought one
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer agitates but won't spin Bab Washer Repair 2 01-08-2012 04:54 PM
washer agitates but won't spin` mls6089 Washer Repair 1 01-08-2012 04:53 PM
Top loader Washer Agitates, but no spin.. with smoke and burn Maytagburned Washer Repair 0 02-05-2010 09:02 PM
Washer agitates but does not spin gjohnson Washer Repair 0 12-27-2008 11:36 AM
Washer agitates, but doesn't spin Cerickson Washer Repair 0 01-05-2008 10:57 AM
