Discuss
Maytag Leaking at Center Shaft
 in
Washer Repair
Greetings, Gurus! My otherwise dependable Maytag has sprung a leak. From the service manual , it appears that there are
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Leaking at Center Shaft
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-04-2010, 01:55 PM
qwe qwe is offline
Junior Member
qwe is on a distinguished road
Default Maytag Leaking at Center Shaft
Model Number: LAT9706AAE   Brand: Maytag   Age: More than 10 years
Greetings, Gurus!
My otherwise dependable Maytag has sprung a leak. From the service manual, it appears that there are two different seals that could be causing the problem. Unfortunately, I cannot make out the scanned photos illustrated in that manual. I've attached a photo of my washer, instead.
After opening the front panel, I have water coming down the center shaft. I removed the agitator, but apparently I need a special tool to go any further.
Through trial and error, I've determined that the machine begins to leak once the water level reaches that black rubber gasket atop that center ... not sure what its called, but I marked it in the photo.
I'm thinking I need what the manual calls a "center shaft seal" but I can find no reference to that in any online parts catalog. Am I correct in thinking that I need to replace that pictured black gasket?
Thank You!
Related Models
Maytag LAT9706AAE WASHER-TOP LOADING
Maytag LAT9706AAM WASHER-TOP LOADING
Maytag LAT9706AAQ WASHER-TOP LOADING
Maytag LAT9706ABE WASHER-TOP LOADING
Maytag LAT9714AAE WASHER-TOP LOADING
Maytag LAT9714AAL WASHER-TOP LOADING
Maytag LAT9714AAM WASHER-TOP LOADING
Maytag LAT9734AAE WASHER-TOP LOADING
Maytag LAT9734AAL WASHER-TOP LOADING
Maytag LAT9734AAM WASHER-TOP LOADING
Maytag LAT9734ABE WASHER-TOP LOADING
Maytag LAT9757AAE WASHER-TOP LOADING
Maytag LAT9757AAM WASHER-TOP LOADING
Maytag LAT9766AAE WASHER-TOP LOADING
Maytag LAT9800AAL WASHER-TOP LOADING
Maytag LAT9800AAW WASHER-TOP LOADING
Maytag LAT9800ABL WASHER-TOP LOADING
Maytag LAT9800ABW WASHER-TOP LOADING
Maytag LAT9800AGL WASHER-TOP LOADING
Maytag LAT9800AGW WASHER-TOP LOADING
Maytag LAT9804AAE WASHER-TOP LOADING
Maytag LAT9804AAL WASHER-TOP LOADING
Maytag LAT9804AAM WASHER-TOP LOADING
Maytag LAT9804ABE WASHER-TOP LOADING
Maytag LAT9806AAE WASHER-TOP LOADING
Maytag LAT9806AAM WASHER-TOP LOADING
Maytag LAT9806ABE WASHER-TOP LOADING
Admiral LAT9806AGE WASHER-TOP LOADING
Admiral LAT9806AKM WASHER-TOP LOADING
Admiral LAT9806AKQ WASHER-TOP LOADING
Admiral LAT9806BGE WASHER-TOP LOADING
Admiral LAT9806DAM WASHER-TOP LOADING
Admiral LAT9806DAQ WASHER-TOP LOADING
Admiral LAT9806GGE WASHER-TOP LOADING
Maytag LAT9824AAE WASHER-TOP LOADING
Maytag LAT9824AAL WASHER-TOP LOADING
Maytag LAT9824AAM WASHER-TOP LOADING
Maytag LAT9824ABE WASHER-TOP LOADING
Maytag LAT9824ABL WASHER-TOP LOADING
Maytag LAT9824ABM WASHER-TOP LOADING
Admiral LAT9824AGE WASHER-TOP LOADING
Admiral LAT9824AKM WASHER-TOP LOADING
Admiral LAT9824BGE WASHER-TOP LOADING
Admiral LAT9824DAM WASHER-TOP LOADING
Admiral LAT9824GGE WASHER-TOP LOADING
Maytag LAT9900AAL WASHER-TOP LOADING
Maytag LAT9900AAW WASHER-TOP LOADING
Maytag LAT9900ABL WASHER-TOP LOADING
Maytag LAT9900ABW WASHER-TOP LOADING
Maytag LAT9904AAE WASHER-TOP LOADING
Maytag LAT9904AAL WASHER-TOP LOADING
Maytag LAT9904AAM WASHER-TOP LOADING
Maytag LAT9904ABE WASHER-TOP LOADING
Admiral LATA100AAE WASHER-TOP LOADING
Admiral LATA100AAL WASHER-TOP LOADING
Admiral LATA100AAM WASHER-TOP LOADING
Admiral LATA100AAW WASHER-TOP LOADING
Admiral LATA100AGE WASHER-TOP LOADING
Admiral LATA100AJE WASHER-TOP LOADING
Admiral LATA100AKE WASHER-TOP LOADING
Admiral LATA100ARE WASHER-TOP LOADING
Admiral LATA200AAE WASHER-TOP LOADING
Admiral LATA200AAL WASHER-TOP LOADING
Admiral LATA200AAM WASHER-TOP LOADING
Admiral LATA200AAW WASHER-TOP LOADING
Admiral LATA200AGE WASHER-TOP LOADING
Admiral LATA200AJE WASHER-TOP LOADING
Admiral LATA200AJM WASHER-TOP LOADING
Admiral LATA300AAE WASHER-TOP LOADING
Admiral LATA300AAL WASHER-TOP LOADING
Admiral LATA300AAM WASHER-TOP LOADING
Admiral LATA300AAW WASHER-TOP LOADING
Admiral LATA300AGL WASHER-TOP LOADING
Admiral LATA300AGW WASHER-TOP LOADING
Admiral LATA400AAE WASHER-TOP LOADING
Admiral LATA400AAL WASHER-TOP LOADING
Admiral LATA400AAM WASHER-TOP LOADING
Admiral LATA400AAW WASHER-TOP LOADING
Admiral LATA400AGE WASHER-TOP LOADING
Admiral LATA400AKE WASHER-TOP LOADING
Admiral LATA400AKL WASHER-TOP LOADING
Admiral LATA400ASE WASHER-TOP LOADING
Admiral LATA401AGE WASHER-TOP LOADING
Admiral LATA401AGM WASHER-TOP LOADING
Admiral LATA401AKE WASHER-TOP LOADING
Admiral LATA401ARE WASHER-TOP LOADING
Admiral LATA500AAE WASHER-TOP LOADING
Admiral LATA500AAL WASHER-TOP LOADING
Admiral LATA500AAW WASHER-TOP LOADING
Hoover LATH100AAM WASHER-TOP LOADING
Hoover LATH100AAV WASHER-TOP LOADING
Hoover LATH100AKM WASHER-TOP LOADING
Hoover LATH100AKV WASHER-TOP LOADING
Hoover LATH100ARV WASHER-TOP LOADING
Hoover LATH100ARW WASHER-TOP LOADING
Hoover LATH100ATV WASHER-TOP LOADING
Hoover LATH300AAV WASHER-TOP LOADING
Hoover LATH300AKM WASHER-TOP LOADING
Hoover LATH300AKV WASHER-TOP LOADING
Hoover LATH300ARV WASHER-TOP LOADING
Hoover LATH300ATV WASHER-TOP LOADING
Hoover LATH400AAV WASHER-TOP LOADING
Hoover LATH400ATV WASHER-TOP LOADING
 LAU091CNP Air Conditioner
 LAU091HNP Air Conditioner
 LAU095HV Air Conditioner
 LAU121HNM Air Conditioner
 LAU121HNP Air Conditioner
 LAU125HV Air Conditioner
 LAU181CNW Air Conditioner
 LAU185HV Air Conditioner
 LAU245HV Air Conditioner
Maytag LAV3600AWW WASHER-TOP LOADING
Maytag LAW2400AAE WASHER-TOP LOADING
Maytag LAW2401AAE WASHER-TOP LOADING
Maytag LAW7500AAL WASHER-TOP LOADING
Maytag LAW7500AAW WASHER-TOP LOADING
Maytag LAW7500ABL WASHER-TOP LOADING
Maytag LAW7500ABW WASHER-TOP LOADING
Maytag LAW7500ABX WASHER-TOP LOADING
  #2 (permalink)
Old 02-05-2010, 06:24 AM
qwe qwe is offline
Junior Member
Default
I found this other thread here in the forums where they fixed a leak with something called "goop". I found a reference to a product called Plumbers Goop at another site. Would something like this work in this situation?
  #3 (permalink)
Old 01-12-2013, 02:16 PM
Junior Member
30dodgeboy is on a distinguished road
Default
Thank You!
I realize your post is old, but wanted to post what I have learned for others in the future...
That seal you marked appears to be part of the mounting stem. I just purchased a 6-2095720 kit to repair my older A308 model Maytag and see my replacement part is identical to your picture. My original stem has a different type of seal held in place with a snap ring exactly as shown in the A308 maytag parts illustration: https://www.maytag.com/digitalassets...20-%20A308.pdf
I 'think' the OEM stems used a A4298 seal held in with a snap ring, and (newer?) replacement stems have a different seal pressed into the stem as an assembly.
Regarding your water leak - the seal you identified could be bad, or the surface of the agitator shaft that it rides on might be corroded/pitted.
Replacement of the seal and/or shaft requires stem removal (and the spanner wrench). Once you have it all apart, you will see the shaft's seal surface as well. For my A308, the shaft appears to be only available in the 22002124 kit, which also includes the items that make up the 6-2095720 seal kit.
This repair guide is helpful as well:
Maytag Washing Machine Repairs | Washing Machine Repair Manual
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore leaking at pump shaft, doesn't wash takoateli Dishwasher Repair 3 12-23-2009 10:53 PM
Diassemble Maytag Neptune Drying Center MaytagNeptune Dishwasher Repair 1 12-08-2009 05:33 PM
Whirlpool washer leaking drain pump stuck to motor shaft, how to separate to replace? ennemm Washer Repair 1 05-03-2009 01:03 PM
Maytag Neptune TL Spinner Shaft Seal cpak Washer Repair 0 01-23-2009 04:43 PM
drain valve seal was leaking and shaft pulled out David Melvin Dishwasher Repair 1 07-30-2008 03:31 PM
