Discuss
Fill cycle not working.
 in
Washer Repair
My Bosch washing machine is not filling the drum on the fill cycle no the rinse cycle. The water is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Fill cycle not working.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 04-25-2008, 09:44 AM
stompy27 stompy27 is offline
Junior Member
stompy27 is on a distinguished road
Default Fill cycle not working.
Model Number: WFK 2401   Brand: Bosch   Age: 5 - 10 years
My Bosch washing machine is not filling the drum on the fill cycle no the rinse cycle. The water is just trickling in. Is this the dual valve? The valve that opens for the detergent and softener works fine. Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-25-2008, 10:09 AM
glen65 glen65 is offline
Senior Expert
APP Volunteer
glen65 is on a distinguished road
Default
Does it make any difference when you switch the wash temperature settings?
  #3 (permalink)
Old 04-25-2008, 10:53 AM
Junior Member
Default
Thanks for the response. No, same result on the hot or cold settings. All cycles.
  #4 (permalink)
Old 04-29-2008, 08:40 AM
Junior Member
Default
Glen are you still avbl to diagnose?
  #5 (permalink)
Old 04-29-2008, 11:58 AM
Senior Expert
APP Volunteer
Default
The first thing to do would be to turn off the water and remove the
fill hoses from the back of the washer and
place them into something. Then turn the water on to make
sure you’re getting proper water pressure. Also check the
screens that are inserted into the water valve where they
connect to the washer. If they need cleaned do not remove them.
take a small brush and clean them.
  #6 (permalink)
Old 04-29-2008, 01:19 PM
Junior Member
Default
Glen Thanks. I have gone thru that procedure already. All screens are clear and water pressure is excellent.
  #7 (permalink)
Old 05-08-2008, 11:10 AM
Junior Member
Default
Glen,
Are you avbl to reply to my last entry? Thanks, Fred
  #8 (permalink)
Old 05-09-2008, 12:36 PM
Senior Expert
APP Volunteer
Default
Sorry 'bout that, (I’ve been tied up trying to see I can make a
buck on this end)
Below is the entire water system for your washer,
number 6 is the inlet valve.
Take each number 7 hose loose from where
it connects to number 23 “only one at a time”
and place the end of that hose into some sort of
container or jar that can hold water. Start the
washer on a warm wash. Does the water just
trickle out into the container? Or does it come out
normally? Make sure to do this test with only
one hose at a time making sure that the other
is still connected.
  #9 (permalink)
Old 05-09-2008, 01:27 PM
Junior Member
Default
I will give it a try. If the trickle originates there would the part # 6, the dual valve, be what i need to replace? Thanks for the response, Fred.
  #10 (permalink)
Old 05-09-2008, 05:08 PM
Senior Expert
APP Volunteer
Default
Quote:
Maybe,
but before that conclusion is reached it would be a
good idea to check and see if proper voltage is getting to
the valve during fill. You should be getting 120 Volts AC
at the terminals of each of the two coils of the valve.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag washer wiil fill slow on spin cycle sancortez Washer Repair 0 04-11-2008 06:34 PM
Spin cycle not working Rappl Washer Repair 0 02-19-2008 07:31 AM
GE Dryer Stops working in mid cycle ToolMan In Training Dryer Repair 1 12-12-2007 09:52 AM
defrost cycle not working tottalyoff Refrigerator & Freezer Repair 3 10-08-2007 12:20 PM
Fill cycle overflows jpcamping Washer Repair 0 09-24-2007 10:41 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
