Discuss
Neutral drain Question
 in
Washer Repair
Hello, I had a quick question. I am "trying" to repair a washer and the gear inside was
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Neutral drain Question
  #1 (permalink)
Old 04-24-2008, 08:07 PM
trini trini is offline
Junior Member
trini is on a distinguished road
Default Neutral drain Question
Model Number: GSL9365EQ2   Brand: Whirlpool   Age: 5 - 10 years
Hello,
I had a quick question. I am "trying" to repair a washer and the gear inside was trashed anyways, I have the transmission apart and I am looking at the Neutral Drain. There are 3 "arms" levers or whatever. 2 plastic (1 with a spring, 1 without) and 1 longer metal one. I know how the plastic ones go in, but what about the metal one?
It seems like it just dangles there. I see where it has a groove on the bottom where it sits on the metal plate but it just seems to dangle. Is there a detailed diagram of how this thing is suppose to go together? or is it just suppose to dangle? From what is there it has 1 peg more towards one side and thats it that holds it on.
I have looked at the diagram of the repair but it really doesnt show it in detail.
Thanks for your help and time in advance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-24-2008, 09:47 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Maybe some of these photos will help you.
Collection of 32 Direct Drive Gear Case - Transmission Photos
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
  #3 (permalink)
Old 04-24-2008, 11:13 PM
Junior Member
Default
Thanks, I appreciate it a lot!
  #4 (permalink)
Old 04-25-2008, 01:50 PM
Junior Member
Default
Hello again,
I had a quick question. When I took apart my transmission it didn't have a Thrust bearing ( WHIRLPOOL Thrust bearing, part number: 285205 ) I ordered one, looking at the pictures the round ball goes on the bottom then the solid washer goes on top. Since I didnt see either of these in my transmission but according to the parts list it should be there I just want to make sure that I put it on right. And also it is a snug fit so I assume I put oil then the ball then the washer?
Thanks again for your time!
  #5 (permalink)
Old 04-25-2008, 06:39 PM
Junior Member
Default
Sorry for yet another question on this. This will be my last then it's going to the recycling yard...
I received the new gear, and it works up till the spin cycle. It makes the noise of spinning but wont spin. So I took it all apart again (sigh) took apart the transmission again and the top gear wont turn the pinion if there is any amount of pressure. So I am assuming it's just junk? I have it put together the same way it was, and according to the diagram but before it would spin and now it wont.
The nylon gear is not tight on the gear below it. If I hold either the pinion or the nylon gear it doesn't turn. Any help would be great! but I assume it's either a new transmission or a new washer.
Quick update, I believe the Neutral drain kit is bad. I have it in position button it up put it in washer and it will spin, once it stops spinning the first time it wont ever start back up.
Thanks everyone for there help, Off to the recycle yard for this heap. It has consistantly broke down every 6-8months since I bought it 8yrs ago.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maintenance question Bart654 Oven Repair (including Ranges and Cooktops) 1 04-01-2008 02:56 PM
Gasket Question wfitzparts Refrigerator & Freezer Repair 1 03-17-2008 08:26 PM
Ice Maker Question Bernie Meyers Refrigerator & Freezer Repair 0 02-19-2008 09:31 AM
Unusual question Elena General Talk 6 12-20-2007 01:27 PM
ignitor question Rod Weeks Oven Repair (including Ranges and Cooktops) 0 11-15-2007 07:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
