Discuss
Fridigdaire washer is leaking from bottom and not draining
 in
Washer Repair
During a wash cycle, it began leaking water from the bottom of the washer. It agitates and spins but does
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Fridigdaire washer is leaking from bottom and not draining
  #1 (permalink)
Old 02-02-2010, 03:07 PM
Junior Member
gevola4320 is on a distinguished road
Default Fridigdaire washer is leaking from bottom and not draining
Model Number: FWX223LBS7   Brand: Frigidaire   Age: 5 - 10 years
During a wash cycle, it began leaking water from the bottom of the washer. It agitates and spins but does not empty water through the hose. There is also a burning smell. Help?
Related Models
Frigidaire FWX223LBS7 Frg(v0) / Free Standing Washer
Frigidaire FWX223LBS8 Frg/washer
Frigidaire FWX225RHS0 Frg(v0) / Washer
Frigidaire FWX225RHS1 Frg/washer
Frigidaire FWX233MRES0 Frg(v0) / Refrigerator
Frigidaire FWX233NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX233NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX233NBS2 Frg(v1) / Washer
Frigidaire FWX233NBS3 Frg(v0) / Washer
Frigidaire FWX233RES0 Frg(v0) / Washer
Frigidaire FWX233RES1 Frg(v0) / Washer
Frigidaire FWX233RES2 Frg(v0) / Washer
Frigidaire FWX233RES3 Frg(v0) / Washer
Frigidaire FWX233RES4 Frg(v0) / Washer
Frigidaire FWX233RES5 Frg(v0) / Washer
Frigidaire FWX233RES6 Frg/washer
Frigidaire FWX233RES7 Washer - Frigidaire
Frigidaire FWX233RET0 Frg(v0) / Free Standing Washer
Frigidaire FWX233RET1 Frg/washer
Frigidaire FWX414RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWX414RGS1 Washer - Frigidaire
Frigidaire FWX433RBS0 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS2 Frg(v3) / Washer
Frigidaire FWX433RBS3 Frg(v1) / Washer
Frigidaire FWX433RBS4 Frg(v1) / Washer
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
Frigidaire FWX435RHS1 Washer - Frigidaire
Frigidaire FWX435RHT0 Frg(v0) / Washer
Frigidaire FWX435RHT1 Washer - Frigidaire
Frigidaire FWX445LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS1 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS2 Frg(v1) / Washer
Frigidaire FWX445LBS3 Frg(v2) / Washer
Frigidaire FWX445LBS4 Frg(v0) / Washer
Frigidaire FWX445NBS0 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS2 Frg(v3) / Washer
Frigidaire FWX445NBS3 Frg(v2) / Washer
Frigidaire FWX445NBS4 Frg(v0) / Washer
Frigidaire FWX445RFS0 Frg(v1) / Washer
Frigidaire FWX445RFS1 Frg(v1) / Washer
Frigidaire FWX445RFS2 Frg(v1) / Washer
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
Frigidaire FWX445RFT4 Frg(v2) / Free Standing Washer
Frigidaire FWX645DBD0 Frg(v2) / 27 " Washer
Frigidaire FWX645DBD1 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW0 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW1 Frg(v2) / 27 " Washer
Frigidaire FWX645GES0 Frg(v0) / Washer
Frigidaire FWX645GES1 Frg(v0) / Washer
Frigidaire FWX645LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX645LBS2 Frg(v4) / Washer
Frigidaire FWX645LBS3 Frg(v3) / Washer
Frigidaire FWX645LBS4 Frg(v1) / Washer
Frigidaire FWX645LBT2 Frg(v5) / Washer
Frigidaire FWX645LBT4 Frg(v2) / Washer
Frigidaire FWX645NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS1 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS2 Frg(v2) / Washer
Frigidaire FWX645NBS3 Frg(v0) / Washer
Frigidaire FWX645NBT0 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT1 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT2 Frg(v3) / Washer
Frigidaire FWX645RFS0 Frg(v0) / Washer
Frigidaire FWX645RFS1 Frg(v0) / Washer
Frigidaire FWX6968HW0 Frg(v0) / Washer
Frigidaire FWX6970E FRIGIDAIRE WASHER
Frigidaire FWX6970EW0 Frg(v0) / Washer
Frigidaire FWX6970EW1 Frg(v0) / Washer
Frigidaire FWX6970EW2 Frg(v0) / Washer
Frigidaire FWX6970EW3 Frg(v0) / Washer
Frigidaire FWX6970EW4 Frg/washer
Frigidaire FWX6970EW5 Frg(v0) / Washer
Frigidaire FWX6971E FRIGIDAIRE WASHER
Frigidaire FWX6971EW0 Frg(v0) / Washer
Frigidaire FWX6971EW1 Frg(v0) / Washer
Frigidaire FWX6971EW2 Frg(v0) / Washer
Frigidaire FWX6975E FRIGIDAIRE WASHER
Frigidaire FWX6975EW0 Frg(v0) / Washer
Frigidaire FWX6975EW1 Frg(v0) / Washer
Frigidaire FWX6975EW2 Frg(v0) / Washer
Frigidaire FWX833AS0 Washer - Frigidaire
Frigidaire FWX833AS1 Washer - Frigidaire
Frigidaire FWX833AS2 Frigidaire/washer
Frigidaire FWX833AS3 Frigidaire/washer
Frigidaire FWX833MAS0 Frigidaire/washer
Frigidaire FWX833SAQ0 Washer - Frig/gallery
Frigidaire FWX833SAS0 Washer - Frig/gallery
Frigidaire FWXB23RGS0 Frg(v0) / Washer
Frigidaire FWXB45RGS0 Washer - Frig/best Buy
Frigidaire FWXB45RGS1 Washer - Frig/best Buy
Frigidaire FWY833KAS0 Frigidaire/washer
Frigidaire FWY833KCS0 Frigidaire/washer
Frigidaire FXP18B4AW0 REFRIGERATOR
Frigidaire FXP18B4AW1 FRIGIDAIRE/REFRIGERATOR
Hardwick G-433 SURFACE UNIT- ELE
Hardwick G-436 SURFACE UNIT- ELE
Hardwick G-445 SURFACE UNIT- ELE
Jenn-Air G0206B-8 ELECTRIC GRILL OUTDOOR
Jenn-Air G100 SURFACE UNIT- DDRAFT ELE
Jenn-Air G101 SURFACE UNIT- DDRAFT ELE
Jenn-Air G102 SURFACE UNIT- DDRAFT ELE
Jenn-Air G103 SURFACE UNIT- DDRAFT ELE
Admiral G1110PRA RANGE- F/S STD GAS
Admiral G1110PRW RANGE- F/S STD GAS
Frigidaire G12W
  #2 (permalink)
Old 02-04-2010, 04:47 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
It seems like you may have two problems. The first is a leaking tub seal, which is not too difficult a repair.
Here is the service manual that will take you through the process.
http://frigidaireservicetips.com/pdfs/489_5.pdf
If the washer will not drain you need to check your pump and hoses for an obstruction. If they are clear, then you need to check the pump to see if power is getting to it. If so, replace the pump, if not you may have to replace the timer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freezer plug not draining? leaking water into bottom of fridge mikkz26 Refrigerator & Freezer Repair 1 01-02-2010 07:23 AM
washer leaking from bottom robert sherwood Washer Repair 1 11-29-2009 12:47 PM
washer is leaking from the bottom mike35 Washer Repair 0 04-07-2009 03:38 PM
Washer leaking out the bottom mybrotherskpr Washer Repair 1 03-17-2009 06:29 AM
Washer Leaking from bottom. HELP! ashbranstad Washer Repair 2 12-30-2008 07:24 AM
