Discuss
Washing Machine
 in
Washer Repair
I have an old Whirlpool that fills with water, then immediately drains, not simultaneously and before it enters into an
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washing Machine
  #1 (permalink)
Old 04-23-2008, 01:33 PM
BruceMcCoy BruceMcCoy is offline
Junior Member
BruceMcCoy is on a distinguished road
Default Washing Machine
Model Number: Belt Drive   Brand: Whirlpool   Age: More than 10 years
I have an old Whirlpool that fills with water, then immediately drains, not simultaneously and before it enters into an agitate cycle. I have checked the timer and the wig-wag and both read OK on the ohm-meter. The plungers appear to be operating correctly (they aren't broken and are loose when not energized) and the cams don't look bent. Is there a way that the plungers wouldn't work even when the wig-wag is checking OK?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-23-2008, 03:10 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
i feel problem is the pump drain port remaining open in wash
__________________
  #3 (permalink)
Old 04-23-2008, 03:26 PM
Junior Member
Default
Thanks- I'll check it tonight. Would this prevent the machine from going into the agitate cycle?
  #4 (permalink)
Old 04-23-2008, 04:29 PM
Senior Expert
APP Volunteer
Default
yes, if the set water level is not reached .
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washing Machine Bob Mutersbaugh Washer Repair 4 03-04-2008 12:45 PM
washing machine hub GE Lolo133 Washer Repair 2 01-02-2008 06:24 AM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 03:42 AM
Washing Machine jherriff Washer Repair 1 09-10-2007 12:03 PM
GE washing machine paul Washer Repair 2 07-19-2007 08:13 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
