Register | FAQ's | New Posts | Today's Posts | Extras |
» Washing Machine Coupler/Motor/Brake Shoes? |
![]() Model Number: KAWS677EQ0 Brand: Kitchen Aid Age: More than 10 years
![]() My Kitchen Aid washing machine has been problem prone, and I'm not sure what part is needed this time. Over the past 5 years it has started shaking violently during the spin cycle. I replaced all of the pads under the tub, but that didn't change anything. A couple of years ago I had to replace the transmission, and 2 or 3 times my coupler between the motor and transmission has broken. My coupler broke again 2 days ago. I replaced it and immediately while doing the next load of laundry there is a burning smell with a lot of squeaking noise. The noise and burning smell seems to be coming from the motor. I don't think it's from the transmission. The squeaking noise is not constant. After the washer starts it takes a while for the squeak to occur, and sometimes it goes away. Sometimes it squeaks during the spin cycle too, but not always. I thought I should replace the motor, but could it be that the brake pads are causing the problem? It seems to be very labor intensive to replace the brakes and I don't know how to do that, but it does seem cheaper than the motor. I don't have an amp meter. How can I tell what the real problem is? If I replace the brakes, do I need to buy a manual to figure out how to do that, and do I only need to buy brake pads or will I need to buy a clutch & brake assembly kit? Where do I stop at buying parts to fix this? Related Models Last edited by dvdb : 02-01-2010 at 07:59 PM. Reason: Clarification |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Assuming your problems happen in the spin mode, I think your problems are in the brakes, and you should replace the clutch and brakes. You can either replace the brake assembly as a whole, or look at the very excellent Sticky by Richappy at the top of this page about how to replace the brakes.
You will need a special spanner to take off the large nut under the agitator.
__________________
![]() Quote:
Thanks for the advice. I don't know in which cycle the coupler broke, but by reading the symptoms in richappy's earlier thread I'll bet the brakes have been bad for a few years. I think the clutch may be OK, but I want to fix the washer this weekend and the brakes were not in stock. However, the whole basket drive & brake assembly was in stock so I ordered that part to ship in 2 days. I believe the brake shoes are a part of that assembly, is that correct? I also ordered the spanner wrench so hopefully I'll be able to figure out how to get this thing apart. Do I need to get some special grease to put on the rollers, and if so, how/where do I apply that and what type of grease do I need? |
![]() If you ordered the part AP3094539, it comes with the brake shoes. I use white silicone grease on the rollers.
When replacing the spin tube, you will need to remove the spin basket and lay the washer on it's back to prevent all the turbine oil from coming out on the floor.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
washing machine drum motor will not spin | tehuglen | Washer Repair | 0 | 01-16-2010 07:47 PM |
Washing machine Motor | LinRH | Washer Repair | 2 | 08-27-2009 01:20 PM |
KitchenAid Washing Machine Coupler replacement | Bryanne Patail | Washer Repair | 0 | 03-01-2008 09:17 AM |
