| » Whirlpool Duet F32 |
Model Number: WFW9200 Brand: Whirlpool Age: Less than 1 year
Washer locks the door and starts to fill, after a few seconds it unlocks the door and relocks the door. Then it displays an F32 error code.
It will happen on all cycles, pulling the plug doesnt help either. Water hoses are new and are not kinked. House water press is 45psi. Any Ideas? Thanks, ---Ralph |
Take the botto panel off, and there will be a cheat sheet. I cannot find that code online. If you find the sheet, tell me what it says. You can reach me at my website at ApplianceEducator.com
Had the same problem. Repairman just left. F32 is the code for Pressure Switch Failure. Which was only found on his tech computer. Remove the top panel from the washer by removing the three screws in the top back of the washer. Inside the back right corner is a round plastic box, either black or white, that is the pressure switch box. Check to make sure all the quick connect wires are connected and tight. Unplug washer to reset it. If the cycle fails still with the F32, you'll need to get a new Pressure switch box. If that doesn't fix it then it could be the control box( the bigger rectangular box in the front right that the wires connect to.) Good Luck and Happy Washing! I'm off to do some of that right now.
| Display Modes | |
| Whirlpool Duet Parts | Admin / APP Team | Washer Repair | 10 | 10-25-2008 10:08 AM |
| Whirlpool Duet F11 and F-DL Codes | jjriggs | Washer Repair | 18 | 08-18-2008 01:48 PM |
| Whirlpool Duet Washer | jimgosnell | Washer Repair | 1 | 01-18-2008 02:17 PM |
| Whirlpool washer Duet job aid | richappy | General Talk | 0 | 12-28-2007 04:26 AM |
