| » Gibson--bad bearings? |
Model Number: GWT445RTS1 Brand: Gibson Age: More than 10 years
My washing machine is making clunking noises during the high speed cycle. I removed the front inspection plate and the back. Shocks and spring mounts seem fine. The noise appears to come from the back of the drum. On spinning it w/o the belt, there is a slight scraping sound.
Does this sound like a bearing problem? If not, what is it? How do I replace bearings if they are the problem? Thanks for your expertise, Joe Ads By Google Related Models |
Usually a bearing failure is more associated with an "engine" sound, so you need to check the inner tub support. If it is the bearing, it is not a replaceable item, and you need to replace the back half of the tub, this part here
Part number: AP2578105 Here is a service manual for your Frigidaire made model. http://frigidaireservicetips.com/pdf...ionWashers.pdf
__________________
| Display Modes | |
| Struts or Bearings...how do you tell | cmtierney | Washer Repair | 1 | 01-01-2010 06:50 AM |
| tub bearings? | bogey | Washer Repair | 1 | 11-12-2009 06:27 PM |
| Lid hinge bearings | Boboli | Washer Repair | 3 | 11-21-2008 07:49 AM |
| bearings going bad? | badbikers | Washer Repair | 3 | 05-17-2008 10:25 AM |
