| » Maytag Performa no spin, agitates instead |
Model Number: HAV3460 Brand: Maytag Age: 5 - 10 years
The machine was banging around on spin so i replaced the snubber and the brake and stator while i was at it. It seems that the brake won't release properly. I don't have enough room to add another washer at the drive pulley so it seems that the cam should be traveling enough to release the brake, but i can't spin it in the spin cycle. Two questions: will the machine agitate in spin if the brake doesn't release? and since i replaced the brake and stator, do i need to also use the new design encapsulated thrust bearing assembly?
Some people pry down the shaft with a screwdriver in the shaft groove, others use vise grips and I heard others use weights on the agitator top to force it down, but you must use all of the new thrust washers to get it to release the brake.
__________________
Thanks for your response. i have not replaced the thrust assembly yet. There is no slack in the shaft and the washer is very snug. I'm wondering if the new brake might be slightly different and requires the new encapsulated bearing design.
Quote:
Just r'cvd the new thrust bearing kit, used the thin washer, same problem. Put the thick washer on (aftr wrestling with it for a few hours - even took out the tub), same problem. I'm pretty much at wit's end at this point.
__________________
Maytag HAV3460 |
| Display Modes | |
| Maytag Transmission issue-Agitates in Spin Cycle | davidaw | Washer Repair | 1 | 02-18-2010 06:04 PM |
| Maytag washer agitates in spin cycle | f.wittman | Washer Repair | 1 | 12-06-2009 07:31 AM |
| Maytag front load agitates, no spin | Michael1061 | Washer Repair | 3 | 07-06-2009 02:38 PM |
| Performa Agitates During Spin | WasherFixer | Washer Repair | 0 | 04-16-2009 04:13 PM |
| Maytag Performa Washer won't spin or wash on regular cycle | gidy34 | Washer Repair | 1 | 11-14-2007 09:54 AM |
