Discuss
Maytag LA612 series 2 Filled with water and just hums (doesn't spin)
 in
Washer Repair
The washer just filled up with water and never did anything else. There is a hum sound coming from the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag LA612 series 2 Filled with water and just hums (doesn't spin)
  #1 (permalink)
Old 01-30-2010, 06:20 PM
Junior Member
jhammond50 is on a distinguished road
Default Maytag LA612 series 2 Filled with water and just hums (doesn't spin)
Model Number: LA612 series 2   Brand: Maytag   Age: More than 10 years
The washer just filled up with water and never did anything else. There is a hum sound coming from the behind the controls panel. I am not familiar with washing machines, but I am pretty handy, so if you can point me in the right direction I can try things out.
Thanks in advance for any help.
Related Models
Maytag LA612S WASHER-TOP LOADING
Maytag LA613 WASHER-TOP LOADING
Whirlpool LA6150XSW0
Whirlpool LA6150XSW1
Whirlpool LA6150XTF0
Whirlpool LA6150XTG0
Whirlpool LA6150XTG1
Whirlpool LA6150XTM0
Whirlpool LA6150XTN0
Whirlpool LA6150XTN1
Whirlpool LA6150XTW0
Whirlpool LA6150XTW1
Whirlpool LA6200XPW3
Whirlpool LA6200XSW0
Frigidaire LA625EXD3 Wwh(v16) / Top Loading Washer
Frigidaire LA625EXF3 Wwh(v17) / Top Loading Washer
Frigidaire LA625EXH3 Wwh(v18) / Top Loading Washer
Frigidaire LA625EXV3 Wwh(v19) / Top Loading Washer
Frigidaire LA625EXW3 Wwh(v20) / Top Loading Washer
Frigidaire LA625JXD3 Wwh(v6) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXD4 Wwh(v11) / Top Load Washer
Frigidaire LA625JXD5 Wwh(v5) / Top Load Washer
Frigidaire LA625JXF3 Wwh(v7) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXF4 Wwh(v12) / Top Load Washer
Frigidaire LA625JXH3 Wwh(v8) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXH4 Wwh(v13) / Top Load Washer
Frigidaire LA625JXV3 Wwh(v9) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXV4 Wwh(v14) / Top Load Washer
Frigidaire LA625JXW3 Wwh(v10) / Top Loading Automatic Agitator Washer
Frigidaire LA625JXW4 Wwh(v15) / Top Load Washer
Frigidaire LA625JXW5 Wwh(v6) / Top Load Washer
Frigidaire LA625MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA625MXW1 Wwh(v3) / 27 " Washer
Whirlpool LA6300XPW0
Whirlpool LA6300XPW1
Whirlpool LA6300XPW2
Whirlpool LA6300XPW3
Whirlpool LA6300XPW4
Whirlpool LA6300XPW5
Whirlpool LA6300XPW6
Whirlpool LA6300XPW7
Whirlpool LA6300XSW0
Whirlpool LA6300XSW1
Whirlpool LA6300XTF0
Whirlpool LA6300XTF1
Whirlpool LA6300XTG0
Whirlpool LA6300XTG1
Whirlpool LA6300XTM0
Whirlpool LA6300XTM1
Whirlpool LA6300XTN0
Whirlpool LA6300XTN1
Whirlpool LA6300XTW0
Whirlpool LA6300XTW1
Whirlpool LA6301XSW0
Whirlpool LA6380XPW0
Whirlpool LA6380XPW1
Whirlpool LA6380XSW0
Whirlpool LA6400XKW0 Washers*
Whirlpool LA6400XPW0 Washers*
Whirlpool LA6400XPW1 Washers*
Whirlpool LA6400XPW3 Washers*
Whirlpool LA6400XPW4 Washers*
Whirlpool LA6400XPW5 Washers*
Whirlpool LA6400XPW6 Washers*
Frigidaire LA640AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA640AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA640AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA640AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA640JXD3 Wwh(v1) / Top Loading Automatic Agitator Washer
Frigidaire LA640JXD4 Wwh(v1) / Top Load Washer
Frigidaire LA640JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA640JXW3 Wwh(v2) / Top Loading Automatic Agitator Washer
Frigidaire LA640JXW4 Wwh(v2) / Top Load Washer
Frigidaire LA640JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA640MXD2 Wwh(v2) / 27 " Washer
Frigidaire LA640MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA640MXW2 Wwh(v1) / 27 " Washer
Whirlpool LA6500XPW0 Washers*
Whirlpool LA6500XPW1 Washers*
Whirlpool LA6500XPW2 Washers*
Whirlpool LA6500XPW4 Washers*
Whirlpool LA6500XPW5 Washers*
Whirlpool LA6500XPW6 Washers*
Whirlpool LA6500XSW0 Washers*
Frigidaire LA650AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA650AXD2 Wwh(v4) / 27 " Washer
Frigidaire LA650AXD3 Wwh(v1) / 27 " Washer
Frigidaire LA650AXW1 Wwh(v3) / 27 " Washer
Frigidaire LA650AXW2 Wwh(v3) / 27 " Washer
Frigidaire LA650AXW3 Wwh(v2) / 27 " Washer
Frigidaire LA650EXD3 Wwh(v1) / Washer
Frigidaire LA650EXF3 Wwh(v2) / Washer
Frigidaire LA650EXH3 Wwh(v3) / Washer
Frigidaire LA650EXV3 Wwh(v4) / Washer
Frigidaire LA650EXW3 Wwh(v5) / Washer
Frigidaire LA650JXD3 Wwh(v11) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXD4 Wwh(v3) / Top Load Washer
Frigidaire LA650JXD5 Wwh(v4) / Top Load Washer
Frigidaire LA650JXF3 Wwh(v12) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXF4 Wwh(v4) / Top Load Washer
Frigidaire LA650JXH3 Wwh(v13) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXH4 Wwh(v5) / Top Load Washer
Frigidaire LA650JXH5 Wwh(v5) / Top Load Washer
Frigidaire LA650JXV3 Wwh(v14) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXV4 Wwh(v6) / Top Load Washer
Frigidaire LA650JXW3 Wwh(v15) / Top Loading Automatic Agitator Washer
Frigidaire LA650JXW4 Wwh(v7) / Top Load Washer
Frigidaire LA650JXW5 Wwh(v6) / Top Load Washer
Frigidaire LA650MXD1 Wwh(v4) / 27 " Washer
Frigidaire LA650MXW1 Wwh(v3) / 27 " Washer
Whirlpool LA6680XPW0
Whirlpool LA6680XPW1
Whirlpool LA6680XSW0
Whirlpool LA6700XKW1
Whirlpool LA6700XKW2
Whirlpool LA6700XMW0
Whirlpool LA6800XKW0
Whirlpool LA6800XKW1
Whirlpool LA6800XKW3
Whirlpool LA6800XMW0
  #2 (permalink)
Old 01-31-2010, 08:32 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If the hum stops, your motor is shutting down on it's thermal shutoff. You have a reliable timer on this AP4023918 made by Kingston.
I would check your motor for bad bearings or something jammed.
__________________
  #3 (permalink)
Old 01-31-2010, 08:56 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
If the hum is the timer, you might just have a bad lid switch. Unplug the washer, and I believe on that model ther are 2 phillip head screw onthe top left odf the control panel, remove the inside one, and do the same on the other side. If it just has 1 one each side remove them. Once that is done, you will see that black lid switch. Take the 2 wires off of the switch, and put the terminal ends together, and put some tape around it to keep it together, and be sure the tape covers the metal terminal, so it does not hit metal. Plug the washer in, and throw the timer in a spin cycle, and see if it works. If so, the washer will spin with the lid open. So if you need to run it it will ber fine. If you have little kids in the house, I would not run it with the kids, in case they were to open the washer and stick there arm in there, while it was running. Let me know if that does it. Tom ********************************************
  #4 (permalink)
Old 02-01-2010, 03:53 PM
Junior Member
Default
I tried bypassing the lid switch, but had the same results.
How can I check the motor for bad bearings or for something jamming it?
Would replacing the humming washer timer possibly fix the problem?
Thanks for any help.
  #5 (permalink)
Old 02-01-2010, 05:40 PM
Senior Expert
APP Volunteer
Default
I do not have the wiring diagram. If the hum is in the timer, I would go with the timer. Tom ********************************************
  #6 (permalink)
Old 02-01-2010, 06:29 PM
Junior Member
Default
I just ordered the timer, it was only $40.
Hopefully it works.
  #7 (permalink)
Old 02-01-2010, 06:31 PM
Senior Expert
APP Volunteer
Default
Hopefully it works.
Oh man that is great!! Let me know how it goes. Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer filled with water then went dead volguy Washer Repair 2 07-09-2011 01:17 PM
Kenmore(1998) Series 80 will not start, it hums deacontry Washer Repair 1 08-22-2009 04:26 PM
Amana filled with water, won't spin peewee Washer Repair 4 02-09-2009 08:53 PM
kenmore washer 70 series wont spin and drain water foster13019 Washer Repair 1 12-20-2008 02:05 PM
Maytag Dependble - No Spin/Drain, Motr Hums - Belt Cn Be Rotatd by Hand 2 Start Motor bluestreak Washer Repair 12 12-06-2008 02:53 AM
