Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Maytag LA612 series 2 Filled with water and just hums (doesn't spin) (http://forum.appliancepartspros.com/washer-repair/73932-maytag-la612-series-2-filled-water-just-hums-doesnt-spin.html)
jhammond50 01-30-2010 05:20 PM
The washer just filled up with water and never did anything else. There is a hum sound coming from the behind the controls panel. I am not familiar with washing machines, but I am pretty handy, so if you can point me in the right direction I can try things out.
Thanks in advance for any help.
richappy 01-31-2010 07:32 AM
If the hum stops, your motor is shutting down on it's thermal shutoff. You have a reliable timer on this AP4023918 made by Kingston.
I would check your motor for bad bearings or something jammed.
kayakcrzy 01-31-2010 07:56 AM
If the hum is the timer, you might just have a bad lid switch. Unplug the washer, and I believe on that model ther are 2 phillip head screw onthe top left odf the control panel, remove the inside one, and do the same on the other side. If it just has 1 one each side remove them. Once that is done, you will see that black lid switch. Take the 2 wires off of the switch, and put the terminal ends together, and put some tape around it to keep it together, and be sure the tape covers the metal terminal, so it does not hit metal. Plug the washer in, and throw the timer in a spin cycle, and see if it works. If so, the washer will spin with the lid open. So if you need to run it it will ber fine. If you have little kids in the house, I would not run it with the kids, in case they were to open the washer and stick there arm in there, while it was running. Let me know if that does it. Tom ********************************************
jhammond50 02-01-2010 02:53 PM
I tried bypassing the lid switch, but had the same results.
How can I check the motor for bad bearings or for something jamming it?
Would replacing the humming washer timer possibly fix the problem?
Thanks for any help.
kayakcrzy 02-01-2010 04:40 PM
I do not have the wiring diagram. If the hum is in the timer, I would go with the timer. Tom ********************************************
jhammond50 02-01-2010 05:29 PM
I just ordered the timer, it was only $40.
Hopefully it works.
kayakcrzy 02-01-2010 05:31 PM
Quote:
Hopefully it works.
Oh man that is great!! Let me know how it goes. Tom ********************************************
