why is my topload washer burning up belts i already took it apart and found nothing in the pump ideas anyone?????
If you will post a full model number someone may be able to help you.
Originally Posted by: sidfink43 If you will post a full model number someone may be able to help you.
Thanks Sorry! model ALW480DAW serial# S0002140201 manugacturer # PALW480DAW
The pump on that model is a direct drive, so it should not impact the belt. If the transmission is not causing a problem and the transmission pulley iss turning freely I suggest you check the idler pulley and spring, and the main pulley. They may be warped and not on the same plane as the motor pulley. Here is a service manual, and while it does not mention your model number I think it covers what you have. http://www.servicematters.com/m...ibrary/docs/16022937.pdf
