Discuss
whirlpool washer timer stops during wash
 in
Washer Repair
My washer stops during wash cycle and will start again if i turn off and on or tape the side
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool washer timer stops during wash
  #1 (permalink)
Old 01-30-2010, 10:45 AM
Junior Member
terryballou is on a distinguished road
Default whirlpool washer timer stops during wash
Brand: Whirlpool   Age: 1 - 5 years
My washer stops during wash cycle and will start again if i turn off and on or tape the side of the machine. Is it the timer switch or dial timer or somthing else that needs repair.
  #2 (permalink)
Old 01-31-2010, 09:59 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Since you have not posted a model number I can only give you a generic answer which is to first check the lid switch, and by-pass it to see if that fixes things in which case it will need replacing, or to replace the timer.
Before replacing the timer clean the connections with contact cleaner and reseat and see if that helps.
If you need more info please post the results of what you do and a full model number.
__________________
  #3 (permalink)
Old 01-31-2010, 10:56 AM
Junior Member
Default
sorry i didnt think to put in the model number it is whirlpool lsn1000pq1 serial number cr5012440
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Esate Whirlpool Washer-timer stops once it hits rinse and i manually move to spin joana83 Washer Repair 3 05-17-2009 09:05 AM
Whirlpool washer stops, restarts when timer is advanced manually derr Washer Repair 2 01-21-2009 09:44 AM
Drain pump replaced, now timer stops after wash and will not rinse BeardedDan Washer Repair 1 06-13-2008 11:05 AM
Timer stops after wash cycle YODAUSA Washer Repair 5 05-13-2008 12:12 PM
washer stops after wash cycle john miller Washer Repair 1 12-27-2007 01:55 AM
