| » Whirlpool Gold Spills water |
Model Number: GSX9750PWO Brand: Whirlpool Age: 1 - 5 years
My washer takes forever to fill up. As it is filling up is also spills out water from the bottom. This happen when it is filling up and when it is in the rinse cycle. It takes forever to put water in for the wash or rinse cycle. Can anyone help me out. Thanks
Related Models |
I’m assuming you have adequate pressure going
to the washer hookup lines themselves. Here’s something you can try, Disconnect the fill hoses from the washer and at the water spickets they connect to. If there are any filter screens in either end of the supply hoses check them to see if anything is restricting them, if so clean or replace them. Hold a bucket up to each spicket and turn it on for about 15 seconds in order to flush the lines going to the spickets. If the pressure seems weak then you may an issue with your water system that needs to be looked into. Check the plastic inlet valve hookups on the washer itself. There are filter screens inserted into ends of the valve hookups. Check to see if the screens are plugged or contaminated. If they are you will need to clean them (do not attempt to remove the screens from the valve). You can use a small brush to reach in and clean the valve screens if needed. Reconnect the fill hoses back to the washer and test the machine and let us know how it goes. Hope this helps, |
| Display Modes | |
| Whirlpool Gold Quiet Partner III has minimal water flow | Jace S | Dishwasher Repair | 1 | 02-02-2010 03:27 AM |
| Whirlpool Gold Ult Care II - water fill not stopping at desired setting | JimGarland | Washer Repair | 1 | 09-24-2009 06:21 AM |
| whirlpool gold ice maker not working --water under the refig | markah | Refrigerator & Freezer Repair | 1 | 06-11-2009 06:58 PM |
| Ice maker spills water into ice bin and creates one block of ice. | jtucker | Refrigerator & Freezer Repair | 1 | 08-13-2008 01:00 PM |
| Water Level Problems on whirlpool gold quiet partner III | capt | Dishwasher Repair | 4 | 05-05-2008 08:36 PM |
