Discuss
Washer Wobbling When Spins
 in
Washer Repair
Washer wobbles when it is in spin cycle. When comes to a stop it makes a loud squeek. It will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Wobbling When Spins
  #1 (permalink)
Old 01-29-2010, 11:30 AM
Junior Member
shirleytemple is on a distinguished road
Default Washer Wobbling When Spins
Model Number: MAVT634AWW   Brand: Maytag   Age: 5 - 10 years
Washer wobbles when it is in spin cycle. When comes to a stop it makes a loud squeek. It will occationally smell like buring rubber in spin cycle also. We have checked for level of washer. After every wash cycle is completed the tub is aways tilted a little the same direction each time. I try even small loads and it is still the same. Any ideas of what part/parts can be replaced?
Related Models
Maytag MAVT634AWW WASHER, ATLANTIS
Maytag MAVT734EWW WASHER, ATLANTIS
Maytag MAVT754EWW WASHER, ATLANTIS
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
Maytag MBF2254HEW14 REFRIGERATOR
Maytag MBF2254HEW4 REFRIGERATOR
Maytag MBF2255KEB REF - BOTTOM MOUNTS
Maytag MBF2255KEB11 REFRIGERATOR
Maytag MBF2255KEQ REF - BOTTOM MOUNTS
Maytag MBF2255KEQ11 REFRIGERATOR
Maytag MBF2255KEW REF - BOTTOM MOUNTS
Maytag MBF2255KEW11 REFRIGERATOR
Maytag MBF2256HEB REF - BOTTOM MOUNTS
Maytag MBF2256HEQ REF - BOTTOM MOUNTS
Maytag MBF2256HES REF - BOTTOM MOUNTS
  #2 (permalink)
Old 01-30-2010, 06:32 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Remove the front panel and check for a leaking tub seal, if ok, check base for white plastic shavings. If shavings,you have a bad snubber. Go to my article in the general talk section "Maytag snubber replacement", just crunch that into the search box.
__________________
  #3 (permalink)
Old 02-01-2010, 11:21 AM
Junior Member
Default
Quote:
In the General Talk Section you spoke of replacing the snubber it also sounds like we will have to replace brakes also. What part do you recomend for the replacement of "brakes" according to the part diagram for my model it shows "Brake Roto", " Brake Stator" "Brake Spring and Retainer" " , "Brake Brace" then along with that there could be " Lower Seal Kit", "Spin Bearing". I did not see anything that said brake shoes or pads. Still need help in ordering parts prior to just tearing apart and leaving for a week or so to replace things one at a time. And sorry to ask. Does Trannys mean transmission?
  #4 (permalink)
Old 02-01-2010, 01:54 PM
Senior Expert
APP Volunteer
Default
You can go to web site applianceaid.com for specifics on this job, a detailed explanation is hard to do without being there. Yes tranny is transmission. When you replace the snubber, you can loosten the brake housing screws allowing you to put some light oil on the brake disk, a round thing with a brake pan cemented on, thus you may not need to replace the brake disk.
__________________
  #5 (permalink)
Old 02-01-2010, 04:55 PM
Senior Expert
APP Volunteer
Default
If it wobbles in spin I would check for a loose suspension spring.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Spins only after lifting top lid yotaman2112 Washer Repair 1 11-19-2009 03:50 PM
washer spins slow kenfink Washer Repair 1 04-29-2009 05:43 PM
GE washer sometimes spins sometimes doesn't WJSR2070B2WW Berto Washer Repair 7 01-15-2009 02:34 PM
washer spins sometimes steve needs help Washer Repair 4 10-23-2008 03:38 PM
washer some what spins kent pratt Washer Repair 0 03-02-2008 03:18 PM
