Discuss
oil leaking into drum
 in
Washer Repair
My Speed Queen told loader has started leaking oil into the drum. It's not real bad, but it's enough to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » oil leaking into drum
  #1 (permalink)
Old 04-17-2008, 08:54 PM
Junior Member
DaronDavis is on a distinguished road
Default oil leaking into drum
Model Number: AWM393W   Brand: Speed Queen   Age: 5 - 10 years
My Speed Queen told loader has started leaking oil into the drum. It's not real bad, but it's enough to ruin a load of clothes with oil spots.
Everything works fine, but when it hits the spin cycle it slings small thin streaks of oil out from under the agitator.
I pulled off the agitator, but haven't gone any further.
What I need to know is there a seal I can replace that will solve the problem or is this a larger transmission problem?
If it's just a seal then I'd like to just replace it myself....if it's worse then I may need a new washer.
Any thoughts?
Ads By Google
Related Models
Amana AWM393W Washer - Top Loading
Amana AWM393W2 Washer - Top Loading
Amana AWM432 Washer - Top Loading
Amana AWM452 Washer - Top Loading
Amana AWM472W Washer - Top Loading
Amana AWM472W2 Washer - Top Loading
Amana AWM473W Washer - Top Loading
Amana AWM473W2 Washer - Top Loading
Amana AWM492 Washer - Top Loading
Amana AWM493 Washer - Top Loading
Amana AWM531 Washer - Top Loading
Amana AWM551 Washer - Top Loading
Amana AWM572 Washer - Top Loading
Amana AWM573W Washer - Top Loading
Amana AWM573W2 Washer - Top Loading
Amana AWM592 Washer - Top Loading
Amana AWM593L Washer - Top Loading
Amana AWM593L2 Washer - Top Loading
Amana AWM593W Washer - Top Loading
Amana AWM593W2 Washer - Top Loading
Amana AWM631 Washer - Top Loading
Amana AWM651 Washer - Top Loading
Amana AWM692 Washer - Top Loading
Amana AWM693 Washer - Top Loading
Whirlpool AWMC6020
Whirlpool AWMC6320
Whirlpool AWMC7020
Whirlpool AWMC7021
Whirlpool AWMP4921
Whirlpool AWMP5021
Whirlpool AWMP5023
Whirlpool AWMP5123
Whirlpool AWMP5223
Whirlpool AWMP6022
Whirlpool AWMP6023
Whirlpool AWMP6123
Whirlpool AWMP6223
Whirlpool AWMP7020
Whirlpool AWMS6020
Whirlpool AWMS6021
Whirlpool AWMS8520
Whirlpool AWMS8521
Frigidaire AWP110S2W Kel(v3) / 24 " Washer
Frigidaire AWP220S2W Kel(v4) / 24 " Washer
Frigidaire AWP330A0D Kel(v4) / 24 " Washer
Frigidaire AWP330A0T Kel(v5) / 24 " Washer
Frigidaire AWP330A0W Kel(v6) / 24 " Washer
Frigidaire AWP330A1D Kel(v4) / 24 " Washer
Frigidaire AWP330A1T Kel(v5) / 24 " Washer
Frigidaire AWP330A1W Kel(v6) / 24 " Washer
Frigidaire AWP330F1D Kel(v2) / 24 " Washer
Frigidaire AWP330F1W Kel(v1) / 24 " Washer
Frigidaire AWP330F2D Kel(v2) / 24 " Washer
Frigidaire AWP330F2W Kel(v1) / 24 " Washer
Frigidaire AWP330G1D Kel(v2) / 24 " Washer
Frigidaire AWP330G1W Kel(v1) / 24 " Washer
Frigidaire AWP330H1L Kel(v2) / 24 " Washer
Frigidaire AWP330H1W Kel(v1) / 24 " Washer
Frigidaire AWP330H2D Kel(v2) / 24 " Washer
Frigidaire AWP330H2W Kel(v1) / 24 " Washer
Frigidaire AWP330H3D Kel(v2) / 24 " Washer
Frigidaire AWP330H3W Kel(v1) / 24 " Washer
Maytag AWS  Water Filtration System
Frigidaire AWS100C1D Kel(v1) / Tumble Action Washer
Frigidaire AWS100C1W Kel(v2) / Tumble Action Washer
Whirlpool AWW09040
Whirlpool AWW09041
Whirlpool AWW10540
Whirlpool AWW15040
Whirlpool AX5133VG0
Whirlpool AX5133VG1
Whirlpool AX5133VL0
Whirlpool AX5133VL1
Whirlpool AX5133VW0
Whirlpool AX5133VW1
Whirlpool AX6245VG0
Whirlpool AX6245VG1
Whirlpool AX6245VL0
Whirlpool AX6245VL1
Whirlpool AX6245VW0
Whirlpool AX6245VW1
Whirlpool AXBP4920
Whirlpool AXBP4921
Whirlpool AXC10020
Whirlpool AXC11021
Whirlpool AXC11022
Whirlpool AXC11023
Whirlpool AXC11024
Whirlpool AXC11025
Whirlpool AXC11540
Whirlpool AXC11541
Whirlpool AXC12040
Whirlpool AXC12041
Whirlpool AXC14041
Whirlpool AXC14543
Whirlpool AXC14544
Whirlpool AXC15040
Whirlpool AXC15041
Whirlpool AXCP8020
Whirlpool AXCP8021
Whirlpool AXE04920
Whirlpool AXE05920
Whirlpool AXE06020
Whirlpool AXE06021
Whirlpool AXE09030
Whirlpool AXE11540
Whirlpool AXE14540
Whirlpool AXE15040
Whirlpool AXE18030
Whirlpool AXF07520
Whirlpool AXF10020
Whirlpool AXF11020
Whirlpool AXF12540
Whirlpool AXF13020
  #2 (permalink)
Old 04-18-2008, 03:40 AM
Senior Expert
APP Volunteer
bambiblaster is on a distinguished road
Default
Most likely a seal kit shld do part number AP170657
  #3 (permalink)
Old 04-18-2008, 03:52 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
You can go to the web site www.applianceaid.com for info on replacing the tub seal and bearing. This is at least a two hour job and you may need to rent a gear puller to pull the hub off. Please post results if you do this job.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
can't get drum out dangoad Washer Repair 1 07-10-2009 04:58 PM
Drum Leaking From Front Flange paul gant Washer Repair 0 06-28-2009 12:15 AM
Glide Drum / rusting drum erniedoeg Dryer Repair 1 03-04-2009 10:08 AM
leaking front loader door /drum seal bfd Washer Repair 0 12-22-2008 07:21 PM
icemaker was leaking so I replaced it. Still leaking Laurie Refrigerator & Freezer Repair 1 03-22-2008 09:24 AM
