Discuss
washer tub seal replacement?
 in
Washer Repair
How do u replace the tub seal. I ordered the seal today because water was coming out from the bottom
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer tub seal replacement?
  #1 (permalink)
Old 01-27-2010, 06:39 AM
Junior Member
patricia langston is on a distinguished road
Default washer tub seal replacement?
Brand: Frigidaire   Age: 1 - 5 years
How do u replace the tub seal. I ordered the seal today because water was coming out from the bottom of the center, but im not sure u you need a seal puller or not to remove old one. And also i assuming to put the new one on tighten the bolt will pull the seal in place on the shaft? Can some one please help me.
Thanks, Pat
  #2 (permalink)
Old 01-28-2010, 06:08 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE tub seal replacement lacerdm Washer Repair 1 01-21-2010 10:15 PM
Maytag Washer Tub Seal and Bearing Replacement Paully Washer Repair 1 01-09-2010 03:49 AM
Whirlpool washer thrust seal replacement behind coupler Greg1234 Washer Repair 3 11-11-2009 06:22 PM
GHW9300PW - Whirlpool duet washer - Front tub seal, bellow replacement jingi1234 Washer Repair 0 04-01-2009 06:36 AM
GE Spacemaker washer seal replacement Dennis Botelho Washer Repair 2 12-19-2008 03:30 AM
