Discuss
Door will not lock
 in
Washer Repair
This machine is very similar to the Whirlpool Duet so if you are not familar with this model, perhaps you
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Door will not lock
  #1 (permalink)
Old 08-25-2007, 10:28 AM
hossross hossross is offline
Junior Member
hossross is on a distinguished road
Default Door will not lock
Model Number: KHWS01PMT2   Brand: Kitchen Aid   Age: 1 - 5 years
This machine is very similar to the Whirlpool Duet so if you are not familar with this model, perhaps you have had experence with its sister
Door to front loader will occasionally lock. Error code DLF is displayed which is accurate. Have replaced switch/lock asm and sometimes works, and sometimes not. Have wiggled all connections. When working I have voltage to the solinoid for the lock, when not working it has no voltage. Running through the test cycle, seems to make it work for a while.
Is this a computer problem, I hear the 6 clicks from the computer, before it gives the error code when it will not lock. Additional diagnostic ideas?
Is the solinoid voltage AC or DC I measured on the AC scale, but thought solinoids were DC or electromagnics. Is the voltage still applied after the door locks, or does it stop and then sends out voltage again to unlock the door at end of cycle? IE how much time do I have to measure voltage from when I push the start button?
Last edited by hossross : 08-27-2007 at 09:28 AM. Reason: Added more info about the voltage
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
