Discuss
Kenmore HE3 elite
 in
Washer Repair
Washer goes through entire cycle until sometime in the spin cycle and then show F11 error code. I checked all
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore HE3 elite
  #1 (permalink)
Old 01-26-2010, 12:30 PM
Junior Member
paulws is on a distinguished road
Default Kenmore HE3 elite
Model Number: 110-45872-400   Brand: Kenmore   Age: More than 10 years
Washer goes through entire cycle until sometime in the spin cycle and then show F11 error code. I checked all the connections, wiring, motor turns freely etc. Must be the MCU or CCU unit. How do I test to determine which is the problem?
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 01-28-2010, 04:37 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
There is no real definitive test for these, but check to see if power is getting to the MCU in spin mode. If so, the MCU is probably bad.
Here is a service manual for your Whirlpool made machine.
https://secured.whirlpool.com/Servic...0Job%20Aid.pdf
__________________
  #3 (permalink)
Old 01-31-2010, 07:40 PM
Junior Member
Default
Thanks for the info so far. I ran through a test mode and the washer goes through the entire cycle under test until the last few seconds of the spin part of the test and then shows F11. Any ideas?
  #4 (permalink)
Old 02-01-2010, 06:18 AM
Senior Expert
APP Volunteer
Default
It seems likely the MCU is the problem, but check all of the connections and wiring, and if everything is ok then I suggest replacing the MCU. The problem with this error code on this model is you can never be sure, but the odds are in favor of the MCU.
__________________
  #5 (permalink)
Old 02-07-2010, 11:31 AM
Junior Member
Default
Tested the motor and resistance tested ok, so I decided to remove the mcu per your suggestion. I then decided to try the washer with the mcu connected, but laying outside the machine andit went through the whole cycle. Tried it three more times and still ok. I then reinstalled the mcu and it has done five loads of wash with no problem. Sears wanted $129 to come look and then would have probably chared for a new mcu board, but thanks to this forum and your suggestion, the total cost was $0.
Paul
  #6 (permalink)
Old 02-07-2010, 01:00 PM
Senior Expert
APP Volunteer
Default
That's fanstastic. I suspect there was some type of connection problem or loose wiring and glad you got it fixed at no cost. That's what we like to hear, and thanks for the update.
__________________
  #7 (permalink)
Old 02-16-2010, 08:19 AM
Junior Member
pedroman74 is on a distinguished road
Default Low Ohms reading
Thanks for these tips. I went through all of the connections and tested the continuity at the motor. The manual says the windings should read 6 ohms for normal and that infinity is abnormal. But I am getting less than 1 ohm, about 0.6-0.7 across pins 1-2, 1-3 and 2-3. What would that indicate? A bad motor?
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore elite baldo66 Dryer Repair 0 02-14-2010 01:53 PM
Kenmore Elite goofy0717 Refrigerator & Freezer Repair 3 06-26-2009 04:28 PM
kenmore elite he markclayton Washer Repair 1 06-04-2009 04:03 PM
Kenmore Elite Goeden Dryer Repair 1 05-04-2009 07:04 PM
kenmore elite donbiel Washer Repair 3 03-26-2009 06:38 PM
