Discuss
Old Maytag washer won't run
 in
Washer Repair
I need help. I have an older Maytag washer that just quit running today. It will fill up with water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Old Maytag washer won't run
  #1 (permalink)
Old 01-26-2010, 12:10 PM
Junior Member
joefab is on a distinguished road
Default Old Maytag washer won't run
Model Number: LAT9634AAL   Brand: Maytag   Age: More than 10 years
I need help. I have an older Maytag washer that just quit running today. It will fill up with water but it will not do anything else. It won't spin or drain or agitate and other than filling up with water it makes no noises.
I checked the door switch and it checks out fine.
Am I wrong to assume that it's the timer? It does not advance at all.
Thanks in advance!
Related Models
Maytag LAT9634AAL WASHER-TOP LOADING
Maytag LAT9634AAM WASHER-TOP LOADING
Maytag LAT9634ABE WASHER-TOP LOADING
Maytag LAT9635AAE WASHER-TOP LOADING
Maytag LAT9635AAM WASHER-TOP LOADING
Maytag LAT9700AAL WASHER-TOP LOADING
Maytag LAT9700AAW WASHER-TOP LOADING
Maytag LAT9700ABL WASHER-TOP LOADING
Maytag LAT9700ABW WASHER-TOP LOADING
Maytag LAT9700DAL WASHER-TOP LOADING
Maytag LAT9700DAW WASHER-TOP LOADING
Maytag LAT9704AAE WASHER-TOP LOADING
Maytag LAT9704AAL WASHER-TOP LOADING
Maytag LAT9704AAM WASHER-TOP LOADING
Maytag LAT9704ABE WASHER-TOP LOADING
Maytag LAT9704ABL WASHER-TOP LOADING
Maytag LAT9704ABM WASHER-TOP LOADING
Admiral LAT9704AGE WASHER-TOP LOADING
Admiral LAT9704BGE WASHER-TOP LOADING
Maytag LAT9704DAL WASHER-TOP LOADING
Maytag LAT9704DAM WASHER-TOP LOADING
Admiral LAT9704GGE WASHER-TOP LOADING
Maytag LAT9706AAE WASHER-TOP LOADING
Maytag LAT9706AAM WASHER-TOP LOADING
Maytag LAT9706AAQ WASHER-TOP LOADING
Maytag LAT9706ABE WASHER-TOP LOADING
Maytag LAT9714AAE WASHER-TOP LOADING
Maytag LAT9714AAL WASHER-TOP LOADING
Maytag LAT9714AAM WASHER-TOP LOADING
Maytag LAT9734AAE WASHER-TOP LOADING
Maytag LAT9734AAL WASHER-TOP LOADING
Maytag LAT9734AAM WASHER-TOP LOADING
Maytag LAT9734ABE WASHER-TOP LOADING
Maytag LAT9757AAE WASHER-TOP LOADING
Maytag LAT9757AAM WASHER-TOP LOADING
Maytag LAT9766AAE WASHER-TOP LOADING
Maytag LAT9800AAL WASHER-TOP LOADING
Maytag LAT9800AAW WASHER-TOP LOADING
Maytag LAT9800ABL WASHER-TOP LOADING
Maytag LAT9800ABW WASHER-TOP LOADING
Maytag LAT9800AGL WASHER-TOP LOADING
Maytag LAT9800AGW WASHER-TOP LOADING
Maytag LAT9804AAE WASHER-TOP LOADING
Maytag LAT9804AAL WASHER-TOP LOADING
Maytag LAT9804AAM WASHER-TOP LOADING
Maytag LAT9804ABE WASHER-TOP LOADING
Maytag LAT9806AAE WASHER-TOP LOADING
Maytag LAT9806AAM WASHER-TOP LOADING
Maytag LAT9806ABE WASHER-TOP LOADING
Admiral LAT9806AGE WASHER-TOP LOADING
Admiral LAT9806AKM WASHER-TOP LOADING
Admiral LAT9806AKQ WASHER-TOP LOADING
Admiral LAT9806BGE WASHER-TOP LOADING
Admiral LAT9806DAM WASHER-TOP LOADING
Admiral LAT9806DAQ WASHER-TOP LOADING
Admiral LAT9806GGE WASHER-TOP LOADING
Maytag LAT9824AAE WASHER-TOP LOADING
Maytag LAT9824AAL WASHER-TOP LOADING
Maytag LAT9824AAM WASHER-TOP LOADING
Maytag LAT9824ABE WASHER-TOP LOADING
Maytag LAT9824ABL WASHER-TOP LOADING
Maytag LAT9824ABM WASHER-TOP LOADING
Admiral LAT9824AGE WASHER-TOP LOADING
Admiral LAT9824AKM WASHER-TOP LOADING
Admiral LAT9824BGE WASHER-TOP LOADING
Admiral LAT9824DAM WASHER-TOP LOADING
Admiral LAT9824GGE WASHER-TOP LOADING
Maytag LAT9900AAL WASHER-TOP LOADING
Maytag LAT9900AAW WASHER-TOP LOADING
Maytag LAT9900ABL WASHER-TOP LOADING
Maytag LAT9900ABW WASHER-TOP LOADING
Maytag LAT9904AAE WASHER-TOP LOADING
Maytag LAT9904AAL WASHER-TOP LOADING
Maytag LAT9904AAM WASHER-TOP LOADING
Maytag LAT9904ABE WASHER-TOP LOADING
Admiral LATA100AAE WASHER-TOP LOADING
Admiral LATA100AAL WASHER-TOP LOADING
Admiral LATA100AAM WASHER-TOP LOADING
Admiral LATA100AAW WASHER-TOP LOADING
Admiral LATA100AGE WASHER-TOP LOADING
Admiral LATA100AJE WASHER-TOP LOADING
Admiral LATA100AKE WASHER-TOP LOADING
Admiral LATA100ARE WASHER-TOP LOADING
Admiral LATA200AAE WASHER-TOP LOADING
Admiral LATA200AAL WASHER-TOP LOADING
Admiral LATA200AAM WASHER-TOP LOADING
Admiral LATA200AAW WASHER-TOP LOADING
Admiral LATA200AGE WASHER-TOP LOADING
Admiral LATA200AJE WASHER-TOP LOADING
Admiral LATA200AJM WASHER-TOP LOADING
Admiral LATA300AAE WASHER-TOP LOADING
Admiral LATA300AAL WASHER-TOP LOADING
Admiral LATA300AAM WASHER-TOP LOADING
Admiral LATA300AAW WASHER-TOP LOADING
Admiral LATA300AGL WASHER-TOP LOADING
Admiral LATA300AGW WASHER-TOP LOADING
Admiral LATA400AAE WASHER-TOP LOADING
Admiral LATA400AAL WASHER-TOP LOADING
Admiral LATA400AAM WASHER-TOP LOADING
Admiral LATA400AAW WASHER-TOP LOADING
Admiral LATA400AGE WASHER-TOP LOADING
Admiral LATA400AKE WASHER-TOP LOADING
Admiral LATA400AKL WASHER-TOP LOADING
Admiral LATA400ASE WASHER-TOP LOADING
Admiral LATA401AGE WASHER-TOP LOADING
Admiral LATA401AGM WASHER-TOP LOADING
Admiral LATA401AKE WASHER-TOP LOADING
Admiral LATA401ARE WASHER-TOP LOADING
Admiral LATA500AAE WASHER-TOP LOADING
Admiral LATA500AAL WASHER-TOP LOADING
Admiral LATA500AAW WASHER-TOP LOADING
Hoover LATH100AAM WASHER-TOP LOADING
Hoover LATH100AAV WASHER-TOP LOADING
Hoover LATH100AKM WASHER-TOP LOADING
Hoover LATH100AKV WASHER-TOP LOADING
Hoover LATH100ARV WASHER-TOP LOADING
Hoover LATH100ARW WASHER-TOP LOADING
Hoover LATH100ATV WASHER-TOP LOADING
Hoover LATH300AAV WASHER-TOP LOADING
Hoover LATH300AKM WASHER-TOP LOADING
  #2 (permalink)
Old 01-26-2010, 07:02 PM
Junior Member
oilslinger53 is on a distinguished road
Default
If the switches are good, and the fuse in the switch assembly is good I'd grab the timer knob, and violently push and pull it in, and out, and kinda wiggle it around. sometimes it'll let you know if the timer is the problem. Also could be the receptacle, the water level switch, or the motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 1 01-18-2015 06:44 PM
help with maytag washer tstewy7 Washer Repair 1 12-29-2009 01:54 PM
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 05:21 PM
Maytag Washer Help clueless1 Washer Repair 1 05-15-2009 07:49 PM
maytag washer frogdoc Washer Repair 1 02-22-2008 08:38 PM
