Discuss
Striped nylon gear.
 in
Washer Repair
My washer started making a banging sound during spin cycle the other day. I took it apart and saw the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Striped nylon gear.
  #1 (permalink)
Old 04-15-2008, 09:39 PM
trini trini is offline
Junior Member
trini is on a distinguished road
Default Striped nylon gear.
Model Number: gsl9365eq2   Brand: Whirlpool   Age: 5 - 10 years
My washer started making a banging sound during spin cycle the other day. I took it apart and saw the brake cam driver was broken. So I ordered a clutch set, installed it this evening and to my amazement it still was making this horrible sound.....
I checked the brake and it was good, I turned the transmission and no clunking.. I decided to take apart the transmission to find out what was going on since that was the only place I haven't looked. The nylon gear was shreaded... About half of the gear was smooth as paper. So I know I need a new gear/pinion or a new washer
My question is how would the gear get destroyed? I understand failures etc but if I replace this gear will it most likely happen again? Also I wanted to note that the top cover of the transmission had a ring in it from the gear, so basically it was rubbing the top. I have cleaned the transmission and the only thing I see besides the gear is minor wear on the washers/springs but I would consider it normal.
Any help would be great!
P.s. I would just buy a whole new transmission but ever since I bought this washer it has had problems, I cannot tell you how many times the repair guy has come to fix it, and now that the extended, extended, extended warranty is out it is up to me So needless to say I cannot wait till the day I use this washer for target practice. lol
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-16-2008, 03:49 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Dragging brake shoes will cause this problem. Check the amp draw in dpin, if higher than say 9.5 amps with dry tub, you have this problem, particularly if the basket comes to a jerky stop.To replace the shoes, go to my brake shoe article in the general talk section page 4
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool gear case clutch bryankw Washer Repair 1 04-11-2008 11:32 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
