| » Spin Cycle (again) on Whirlpool Washer |
Model Number: LSQ8520JQO Brand: Whirlpool Age: 5 - 10 years
Spin cycle was making a terrible noise and then just quit. Will restart but the noise is real bad and will not finish the cycle. Checked the coupler, it is fine and was replaced about 2 months ago.
With motor and pump off and turning the drive by hand (other end of coupler non-motor side): on the drive, I can rotate it counter-clockwise indefinately with no problem. Clockwise it will rotate and then stop. I can not budge it. Also, when I try to move the agitator by hand, it is really frozen in place now. Agitator will not turn by turning drive train with motor disconnected. Can you recommend a solution with parts required and a link to the procedure - or has it met its demise. Thanks for past and current help. Ads By Google Related Models |
There are three failure suspects: the clutch, the gear case and the basket drive.
Remove the gear case. Remove the clutch from the gear case and inspect the clutch and the bottom part of the basket drive. Post your findings. Here are the break down diagrams for the Whirlpool washer Model LSQ8520JQ0 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Thank you Gene. I removed the gear case. I was unable to remove the clutch from the gear case (even after the clip was removed), is there a trick?
When holding the clutch, and turning the coupling, it would not grab and jump as if it was stripped. Both halves of the clutch look ok, but not sure I would know if it was damaged. Is there some testing I can do? |
| Display Modes | |
| Whirlpool washer spin cycle | ncalvano | Washer Repair | 4 | 06-02-2012 05:36 PM |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 10 | 05-24-2011 12:25 PM |
| Whirlpool washer spin cycle sporadic? | crowes5 | Washer Repair | 1 | 09-07-2009 11:16 AM |
| Whirlpool Washer will not go into spin cycle | redstang66 | Washer Repair | 9 | 11-06-2008 06:01 AM |
| Whirlpool Washer- Spin Cycle | dbc | Washer Repair | 0 | 01-27-2008 05:45 AM |
