Discuss
Amana washer squeals on spin
 in
Washer Repair
The washer has a very high squeal on spin. What should I look for? Could it be a bearing, idler,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Amana washer squeals on spin
  #1 (permalink)
Old 01-25-2010, 06:08 PM
Junior Member
1dlee54 is on a distinguished road
Default Amana washer squeals on spin
Model Number: LWA50AW   Brand: Amana   Age: 5 - 10 years
The washer has a very high squeal on spin. What should I look for? Could it be a bearing, idler, transmission, brakes or what?
Related Models
Amana LWA50AW WASHER-TOP LOADING
Amana LWA60AL WASHER-TOP LOADING
Amana LWA60AW WASHER-TOP LOADING
Amana LWA65AL WASHER-TOP LOADING
Amana LWA65AW WASHER-TOP LOADING
Amana LWA80AL WASHER-TOP LOADING
Amana LWA80AW WASHER-TOP LOADING
Amana LWA90AL WASHER-TOP LOADING
Amana LWA90AW WASHER-TOP LOADING
Amana LWC05AW WASHER-TOP LOADING
Amana LWC07AW WASHER-TOP LOADING
Amana LWC18AW WASHER-TOP LOADING
Amana LWC30AW WASHER-TOP LOADING
Amana LWC40AW WASHER-TOP LOADING
Amana LWC50AW WASHER-TOP LOADING
Amana LWC75AW WASHER-TOP LOADING
Amana LWC80AW WASHER-TOP LOADING
Amana LWC90AW WASHER-TOP LOADING
Amana LWD250 WASHER-TOP LOADING
Amana LWD27AW WASHER-TOP LOADING
Amana LWD27BW WASHER-TOP LOADING
 LWD3081ST Electric Range
Amana LWD352 WASHER-TOP LOADING
Amana LWD352L WASHER-TOP LOADING
Amana LWD352W WASHER-TOP LOADING
Amana LWD353 WASHER-TOP LOADING
Amana LWD353L WASHER-TOP LOADING
Amana LWD353W WASHER-TOP LOADING
Amana LWD35AW WASHER-TOP LOADING
Amana LWD37AW WASHER-TOP LOADING
Amana LWD40AW WASHER-TOP LOADING
Amana LWD450 WASHER-TOP LOADING
Amana LWD453 WASHER-TOP LOADING
Amana LWD553 WASHER-TOP LOADING
Amana LWD553L WASHER-TOP LOADING
Amana LWD553W WASHER-TOP LOADING
Amana LWD650 WASHER-TOP LOADING
Amana LWD662 WASHER-TOP LOADING
Amana LWD67AL WASHER-TOP LOADING
Amana LWD67AW WASHER-TOP LOADING
Amana LWD70AL WASHER-TOP LOADING
Amana LWD70AW WASHER-TOP LOADING
Amana LWD75AW WASHER-TOP LOADING
Amana LWD773 WASHER-TOP LOADING
Amana LWD773L WASHER-TOP LOADING
Amana LWD773W WASHER-TOP LOADING
Amana LWD850 WASHER-TOP LOADING
Amana LWD862 WASHER-TOP LOADING
Amana LWD950 WASHER-TOP LOADING
Amana LWD962 WASHER-TOP LOADING
Amana LWD973 WASHER-TOP LOADING
Amana LWD973L WASHER-TOP LOADING
Amana LWD973W WASHER-TOP LOADING
Amana LWG65AW WASHER-TOP LOADING
 LWHD1000CR Air Conditioner
 LWHD1000R Air Conditioner
 LWHD1006R Air Conditioner
 LWHD1200FR Air Conditioner
 LWHD1200HR Air Conditioner
 LWHD1200R Air Conditioner
 LWHD122FR Air Conditioner
 LWHD1450ER Air Conditioner
 LWHD1500ER Air Conditioner
 LWHD1800R Air Conditioner
 LWHD1807HR Air Conditioner
 LWHD2400HR Air Conditioner
 LWHD2500ER Air Conditioner
 LWHD6500R Air Conditioner
 LWHD6500SR Air Conditioner
 LWHD7000HR Air Conditioner
 LWHD8000RY6 Air Conditioner
 LWHD8008R.AWYAHDP Air Conditioner
Norge LWJ202A WASHER-TOP LOADING
Norge LWJ202H WASHER-TOP LOADING
Norge LWJ202W WASHER-TOP LOADING
Norge LWJ206A WASHER-TOP LOADING
Norge LWJ206H WASHER-TOP LOADING
Norge LWJ206W WASHER-TOP LOADING
  #2 (permalink)
Old 01-27-2010, 11:43 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Very hard to tell because to diagnose a noise like yours we have to listen to its pitch and location.
I suggest you operate the machine with the front panel off and see if you can locate the area it is coming from. Then use this service manual to try and diagnose the problem, and how to replace parts if you decide to go that route.
http://www.servicematters.com/maytag...S3100005R3.pdf
__________________
  #3 (permalink)
Old 02-23-2010, 12:51 PM
Junior Member
Larrreyer is on a distinguished road
Default
I have the same problem with my washer, also I can not download the repair manual....modelDRW330 RAW
  #4 (permalink)
Old 02-23-2010, 01:27 PM
Junior Member
Default
I took the lower panel off , possibley the lower drum bearing, Also it has been leaking in the bottom, throwing water out during the spin cycle, looks like there may be a seal at the bottom of the tub???????? water is comming off the 'aluminum hub' just below the tub. now what ?
  #5 (permalink)
Old 02-23-2010, 05:31 PM
Senior Expert
APP Volunteer
Default
Please start a new post and someone should be able to help you.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer squeals on spin cycle 330racing Washer Repair 1 01-25-2010 12:08 PM
Amana Washer won't spin kennyg Washer Repair 2 07-22-2009 04:37 PM
Amana washer will not spin on last spin cycle karenmf Washer Repair 1 06-07-2009 08:05 AM
Amana Washer Tub Does Not Spin WOODWORKERPRO1 Washer Repair 6 02-09-2009 07:29 AM
Amana clothes washer squeals and now leaks SZoerb Washer Repair 1 04-16-2008 12:31 PM
