I replaced the belt on an Amana Super Capacity Plus washer. It now works but is very loud when it spins and water builds in the drain tub it sits in. Any info would be greatly appreciated.
Try clearing out the pump and internal drain hoses for an obstruction. Make sure the pump is working ok and then see if that helps.
