Discuss
Cold/Cold will not work, all others do work!?
 in
Washer Repair
Just bought a used GE washer, got it home, it worked great for one day, all temp settings, cold/cold; warm/warm;
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Cold/Cold will not work, all others do work!?
  #1 (permalink)
Old 08-24-2007, 10:10 PM
Junior Member
MiniPants is on a distinguished road
Default Cold/Cold will not work, all others do work!?
Model Number: WWXR4100T   Brand: GE   Age: 5 - 10 years
Just bought a used GE washer, got it home, it worked great for one day, all temp settings, cold/cold; warm/warm; warm/cold; and hot/cold. Today, the cold/cold setting will not work. On cold/cold it will not fill, spin, anything. The other three settings still work fine. We replaced the hoses last night, but after inspection I do not believe the problem has anything to do with the hoses. Any suggestion? My wife thinks it is the "board" that needs to be replaced????
Also, during agitation, the front panel is getting hit by the inside parts and clacking very loud. I was able to quiet the unit done 100% by putting a sock under the front metal panel. Any thoughts on how to get the inside basin centered?
Thank you so much for your help.
Ads By Google
Related Models
General Electric WWXR4100T2AA Washer
General Electric WWXR4100T2WB Washer
General Electric WWXR4100T2WW Washer
General Electric WWXR4100T3AA Washer
General Electric WWXR4100T3WB Washer
General Electric WWXR4100T3WW Washer
General Electric WWXR4100T5AA Washer
General Electric WWXR4100T5WB Washer
General Electric WWXR4100T5WW Washer
General Electric WWXR4100T6AA Washer
General Electric WWXR4100T6WB Washer
General Electric WWXR4100T6WW Washer
General Electric WWXR4100T8AA Washer
General Electric WWXR4100T8WB Washer
General Electric WWXR4100T8WW Washer
General Electric WWXR4100TAAA Washer
General Electric WWXR4100TAWB Washer
General Electric WWXR4100TAWW Washer
General Electric WZRE5260F0GG Washer
General Electric WZRE5260F2GG Washer
General Electric WZSE5310T0WW Washer
General Electric WZSE5310T1WW Washer
Dynasty x  Hood
Whirlpool X05002F00
Whirlpool X05002F01
Whirlpool X05002F02
Whirlpool X05002G0
Whirlpool X05002V0
Whirlpool X05002W00
Whirlpool X05002W01
Whirlpool X05002X00
Whirlpool X05002X01
Whirlpool X05002X02
Whirlpool X05002X03
Whirlpool X05002X04
Whirlpool X05002X05
Whirlpool X05002X06
Whirlpool X05002X07
Whirlpool X07002F00
Whirlpool X07002G0
Whirlpool X07002W00
Whirlpool X07002X00
Whirlpool X07002X01
Whirlpool X07502V0
Whirlpool X10002D00
Whirlpool X10002F00
Whirlpool X10002G0
Whirlpool X10002V1
Whirlpool X10002W00
Whirlpool X10002W01
Whirlpool X10002W02
Whirlpool X10002W03
Whirlpool X10002W04
Whirlpool X12002D00
Whirlpool X12002F00
Whirlpool X12002G0
Whirlpool X12002V0
Whirlpool X12002V01
Whirlpool X12002V02
Whirlpool X12002V03
Whirlpool X12002V04
Whirlpool X18004A0
Whirlpool X18004D00
Whirlpool X18004D01
Whirlpool X18004D02
Whirlpool X18004G0
Whirlpool X18004V0
Whirlpool X24004A0
Whirlpool X24004A1
Whirlpool X24004A2
Whirlpool X24004F00
Whirlpool X24004F01
Whirlpool X24004G0
Thermador X272XB
Thermador X272XP
Thermador X272XS
Thermador X272XW
Thermador X301XB
Thermador X301XP
Thermador X301XS
Thermador X301XW
Thermador X302XB
Thermador X302XP
Thermador X302XS
Thermador X302XW
Maytag X3448XTALT Range - S/c F/s Gas
Maytag X3448XTWLT Range - S/c F/s Gas
Maytag X3488VVDLT Range - S/c F/s Gas
Maytag X3488VVVLT Range - S/c F/s Gas
Maytag X3488XVALT Range - S/c F/s Gas
Maytag X8210RA Surface Unit - Gas
Maytag X8210RW Surface Unit - Gas
Maytag X8241RA Surface Unit - Gas
Maytag X8241RV Surface Unit - Gas
Maytag X8261RB Surface Unit - Gas
Maytag X8261RV Surface Unit - Gas
Maytag X8610RA Surface Unit - Ele
Maytag X8610RT Surface Unit - Ele
Maytag X8610RV Surface Unit - Ele
Maytag X8670RB Surface Unit - Ele
Maytag X8670RV Surface Unit - Ele
Maytag X9112VUV Walloven - Std Gas
Maytag X9112XUB Walloven - Std Gas
Maytag X9875VVB Walloven - S/c Ele
Maytag X9875VVV Walloven - S/c Ele
Maytag X9875XVB Walloven - S/c Ele
Jenn-Air xA100 Ele Cartridge
Whirlpool XAMC891MQ0 Pedestal
Whirlpool XAMC891MQ1 Pedestal
Whirlpool XAMC891MQ2 Pedestal
Whirlpool XAMC892MQ0 Pedestal
Whirlpool XAMC892MQ1 Pedestal
Whirlpool XAMC892MQ2 Pedestal
Whirlpool XAMC893ML0 Pedestal
Whirlpool XAMC893ML1 Pedestal
Whirlpool XAMC893ML2 Pedestal
Maytag XAV13PRBWW Washer - Top Loading
Amana XBR301 Ele Cartridge
Amana XBR301WW Ele Cartridge
Frigidaire XF22CW0
  #2 (permalink)
Old 08-26-2007, 02:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi MiniPants
Before I might be able to help you I need to know if your washer filled up with the cold water during the rinse cycle when you used warm/cold or hot/cold options?
  #3 (permalink)
Old 08-27-2007, 08:24 AM
klt klt is offline
Junior Member
klt is on a distinguished road
Default
Hi Gene,
I'm having similar problem with washer cycle stopping when it is time for the cold water. Mine also stops during rinse. It is a Kenmore Heavy Duty 70 Series, Model 110.82671810, Serial C73217086. The cold water hose isn't clogged. How do I find out if it is the timer or something else?
Karen
  #4 (permalink)
Old 08-27-2007, 12:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Karen
I need to know if your washer filled up with cold water for the main wash?
  #5 (permalink)
Old 08-27-2007, 02:08 PM
klt klt is offline
Junior Member
Default
No, no cold water comes out anytime.
  #6 (permalink)
Old 08-27-2007, 02:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In this case there is no doubt the problem is a bad water valve in your washer.
The part number for the new water mixing valve AP3094541
Good luck.
  #7 (permalink)
Old 08-27-2007, 02:52 PM
klt klt is offline
Junior Member
Default
Awesome Gene, thank you!
  #8 (permalink)
Old 08-27-2007, 03:01 PM
klt klt is offline
Junior Member
Default How to replace Inlet Water Valve on Washer
Hi Gene,
Hate to bother you again, but how do you go about replacing the Inlet Water Valve on the Washer? Please keep in mind, I don't know anything about washers except how to get them going and stop them.
Thank you for your patience
  #9 (permalink)
Old 08-28-2007, 09:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Karen
Here you can find complete instructions:
http://www.repairave.com/washerrepair_wpl_watervalve.asp
Good luck.
  #10 (permalink)
Old 08-30-2007, 03:28 PM
klt klt is offline
Junior Member
Default
Awesome Gene. You were right on with the water inlet valve. That was the problem. I bought the replacement part, but the two holes don't match up on the water inlet valve metal piece and the holes on the water inlet valve cover. I'm going to have to use big washer and make-do to get two screws to hold the water inlet valve to the cover. I can do it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge WASHER, Cold/Cold does not work no1zson Washer Repair 5 01-06-2010 07:06 PM
no cold water on cold/cold cycle rpbmd Washer Repair 1 08-28-2009 10:04 AM
Cold water will not work rychefan Washer Repair 1 08-18-2009 11:02 AM
Fridge won't work in cold garage.h dcrone9 Refrigerator & Freezer Repair 2 04-02-2009 06:50 PM
cold water will not work, bryankw Washer Repair 1 04-11-2008 09:03 PM
