| » Stackable Washer - won't drain, smells like its burning! |
Model Number: FEX831FS1 Brand: Frigidaire Age: 1 - 5 years
I had a friend replace the belt in the washer because it began to smell like it was burning this weekend and the drum would not drain. It goes through the cycle, but does not drain, so then it spins with water in it and makes a wierd noise and smells.
I have the front of the washer exposed now, and our friend said it may be the pump that connects the house from the drum to the hose that goes our of the washer to drain - there is a motor/pump of some sort. Any ideas? He is willing to replace it if I get the part, but I dont want to keep changing things and spending money on parts to keep guessing. Any help is appreciated!!! Ads By Google Related Models |
Before you replace the pump do two things
1. Take off the pump and the drain hoses and make sure there are no obstructions preventing the water from draining. 2. When the machine should be draining, see if you are getting power to the pump. If there is no obstruction and power is getting to the pump then replacing it is your likely solution.
__________________
You will need to use an electrical test meter to measure voltage. Take off the plug on the pump and put the machine into a cycle where it should be pumping. If you do not have one find a handy friend (the one who helped before?) who has one or buy one at the local hardware/tools/big box store. If will come with directions.
These pumps are pretty good, I think it is more likely you have an obstruction or blockage.
__________________
| Display Modes | |
| Whirlpool washer smells like something is burning | D Will | Washer Repair | 4 | 08-06-2011 08:42 AM |
| Dryer smells like burning, won't start | bignick2184 | Dryer Repair | 1 | 08-28-2009 05:38 PM |
| smells like a vacumn or slight burning | jvanpay | Washer Repair | 0 | 08-25-2009 12:21 PM |
| GE microwave smells like something electrical burning | 91seahawk | Microwave Repair | 1 | 03-01-2009 04:19 PM |
| belt smells like burning | fedexsteve | Washer Repair | 1 | 09-08-2008 04:16 PM |
