Discuss
Kelvinator Washer belt replacement?
 in
Washer Repair
I need to know how to replace the drive belt on my Kelvinator AW300G clothes washer. I cant figure out
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kelvinator Washer belt replacement?
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-24-2007, 10:05 AM
Eric Kelsheimer Eric Kelsheimer is offline
Junior Member
Eric Kelsheimer is on a distinguished road
Default Kelvinator Washer belt replacement?
Model Number: AW300G   Brand: Kelvinator   Age: 5 - 10 years
I need to know how to replace the drive belt on my Kelvinator AW300G clothes washer. I cant figure out how to access the belt.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-27-2007, 09:28 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Eric Kelsheimer
In order to get an access to the drive belt you have to remove the front panel from the washer.
Remove two screws from each side on the bottom of the front panel. Using a putty knife or a flat screwdriver push the front panel from the top downward to release it from the locking tabs and pull it out.
- Here are the break down diagrams for the Kelvinator washer Model AW300G1W
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fan Belt Replacement atneffect Dryer Repair 0 08-15-2007 07:23 AM
dryer belt replacement mamasue Dryer Repair 0 08-14-2007 09:00 AM
belt replacement roy Dryer Repair 0 08-11-2007 09:01 AM
Replacement of Dryer Belt kcbrandt11 Dryer Repair 0 08-02-2007 02:25 PM
belt replacement honeypotx5 Washer Repair 0 08-01-2007 06:46 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
