| » kenmore not agitating |
Model Number: 110.26882503 Brand: Kenmore Age: 1 - 5 years
Spin motor works ok but the wash motor trips out at 27amps and there is no movement with the agitation. Does the motor turn in two directions, oue wash and another for spin? is it likely that the transmition needs replaced? thanks for the advice!
Jim |
Jim,
Remove the washer cabinet, remove the pump and the motor. Check if the motor will work while the control calls for the agitation and would not heat up. If you can, check for amps drawn. If it's not working properly and/or heats up then the motor is bad. If there is nothing wrong with the motor - try to move the transmission shaft in both directions. Post your findings. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Gene,
sorry for taking so long to get back I have not been able to get back to the appliance, but can tell you that the motor works in the spin mode. With my amprobe I haad 27amps when power was applied to the agitat motor leeds. The drain pump works when the machine spins The agitator seemed to move freely when I turned it by hand with the machine off. It seems like there is something binding the motor in the agitate only. I am still trying to get back to see the machine. Thanks Jim Last edited by bontree : 04-21-2008 at 04:40 PM. |
bontree
What is going on? Did you find anything? Gene.
__________________
Gene,
I removed the motor and it would not run untill I turned it by hand. Is there a start capacitor on the motor or are the start windings out? Motor works on Spin ok. I will be replacing the motor. thanks for your help. Jim |
__________________
| Display Modes | |
| Kenmore quit agitating and water continues to run | oldparts | Washer Repair | 3 | 03-29-2008 10:14 AM |
| washer not agitating | Kathy Sanchez | Washer Repair | 1 | 03-17-2008 09:25 PM |
| not agitating | Joanna | Washer Repair | 1 | 11-29-2007 02:36 PM |
| Washer not agitating | Todd | Washer Repair | 1 | 09-18-2007 02:45 AM |
| Kenmore 80's series not agitating | leothedog | Washer Repair | 4 | 08-23-2007 10:36 PM |
