Discuss
kenmore broke
 in
Washer Repair
i have a kenmore washer, model # 11092283100 serial# cb4834875. it will not agitate, nor will it spin. the drain works
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore broke
  #1 (permalink)
Old 04-10-2008, 11:23 AM
broke broke is offline
Junior Member
broke is on a distinguished road
Default kenmore broke
Model Number: 11092283100   Brand: Kenmore   Age: More than 10 years
i have a kenmore washer, model # 11092283100 serial# cb4834875. it will not agitate, nor will it spin. the drain works just fine. it does sound like it is operating just fine. there is just no movement. i can spin the agitator and tub by hand. there doesn't seem to be any resistance,nor does it feel too easy. i hope this is enough information.
thanks,
broke
Related Models
Kenmore 11092370200 WASHER
Kenmore 11092572100 WASHER
Kenmore 11092572800 WASHER
Kenmore 11092573010 WASHER
Kenmore 11092573110 AUTOMATIC WASHER
Kenmore 11092573810 AUTOMATIC WASHER
Kenmore 11092573910 WASHER
Kenmore 11092580000 AUTOMATIC WASHER
Kenmore 11092580900 AUTOMATIC WASHER
Kenmore 11092581120 AUTOMATIC WASHER
Kenmore 11092581220 AUTOMATIC WASHER
Kenmore 11092581420 AUTOMATIC WASHER
Kenmore 11092581820 AUTOMATIC WASHER
Kenmore 11092582100 AUTOMATIC WASHER
Kenmore 11092582120 AUTOMATIC WASHER
Kenmore 11092582420 AUTOMATIC WASHER
Kenmore 11092582800 AUTOMATIC WASHER
Kenmore 11092582820 AUTOMATIC WASHER
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11095 CEILING FAN
Kenmore 11096195120 ELECTRIC DRYER
Kenmore 11096195500 ELECTRIC DRYER
Kenmore 11096195510 DRYER FEATURE SHEET
Kenmore 11096195520 ELECTRIC DRYER
Kenmore 11096195800 ELECTRIC DRYER
Kenmore 11096195810 DRYER FEATURE SHEET
Kenmore 11096195820 ELECTRIC DRYER
Kenmore 11096210100 DRYER-FEATURE SHEET
Kenmore 11096220100 DRYER-FEATURE SHEET
Kenmore 11096250100 DRYER-FEATURE SHEET
Kenmore 11096260100 DRYER FEATURE SHEET
Kenmore 11096263100 DRYER-FEATURE SHEET
Kenmore 11096263800 DRYER-FEATURE SHEET
Kenmore 11096264100 DRYER FEATURE SHEET
Kenmore 11096264800 DRYER FEATURE SHEET
Kenmore 11096271100 DRYER FEATURE SHEET
Kenmore 11096271600 DRYER FEATURE SHEET
Kenmore 11096271800 DRYER FEATURE SHEET
Kenmore 11096272000 ELECTRIC DRYER
Kenmore 11096272100 DRYER FEATURE SHEET
Kenmore 11096272600 DRYER FEATURE SHEET
Kenmore 11097091100 GAS DRYER
Kenmore 11097091300 GAS DRYER
Kenmore 11097091700 GAS DRYER
Kenmore 11097091800 GAS DRYER
Kenmore 11097093100 GAS DRYER
Kenmore 11097093300 GAS DRYER
Kenmore 11097093500 GAS DRYER
Kenmore 11097093700 GAS DRYER
Kenmore 11097093800 GAS DRYER
Kenmore 11097094100 GAS DRYER
Kenmore 11097094300 GAS DRYER
Kenmore 11097094500 GAS DRYER
Kenmore 11097094700 GAS DRYER
Kenmore 11097094800 GAS DRYER
Kenmore 11097195100 GAS DRYER
Kenmore 11097195110 DRYER FEATURE SHEET
Kenmore 11097195120 GAS DRYER
Kenmore 11097195500 GAS DRYER
Kenmore 11097195510 DRYER FEATURE SHEET
Kenmore 11097195520 GAS DRYER
Kenmore 11097195800 GAS DRYER
Kenmore 11097195810 DRYER FEATURE SHEET
Kenmore 11097195820 GAS DRYER
Kenmore 11097210100 DRYER-FEATURE SHEET
Kenmore 11097220100 DRYER-FEATURE SHEET
Kenmore 11097250100 DRYER-FEATURE SHEET
Kenmore 11097260100 DRYER FEATURE SHEET
Kenmore 11097264100 DRYER FEATURE SHEET
Kenmore 11097264800 DRYER FEATURE SHEET
Kenmore 11097271100 DRYER FEATURE SHEET
Kenmore 11097271600 DRYER FEATURE SHEET
Kenmore 11097271800 DRYER FEATURE SHEET
Kenmore 11097272100 DRYER FEATURE SHEET
Kenmore 11097272600 DRYER FEATURE SHEET
Kenmore 11097272800 DRYER SPECIFICATIONS
Kenmore 11097273100 DRYER FEATURE SHEET
Kenmore 11097273600 DRYER FEATURE SHEET
Kenmore 11097273800 DRYER FEATURE SHEET
Kenmore 11097274100 DRYER FEATURE SHEET
Kenmore 11097274600 DRYER FEATURE SHEET
Kenmore 11097274800 DRYER FEATURE SHEET
Kenmore 11097278100 DRYER FEATURE SHEET
Kenmore 11097278800 DRYER FEATURE SHEET
Kenmore 11097280100 DRYER FEATURE SHEET
Kenmore 110985000 SEARS DIRECT DISCHARGE WALL FAN
Kenmore 110985100 VERTICAL DISCHARGE FAN
  #2 (permalink)
Old 04-10-2008, 02:59 PM
gearhead1218 gearhead1218 is offline
Member
gearhead1218 is on a distinguished road
Default
Sounds like a failed motor coupler.
A relatively easy repair.
  #3 (permalink)
Old 04-10-2008, 03:15 PM
Junior Member
Default
thank you, i will try this.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag auger assembly broke David Arey Washer Repair 1 01-27-2008 01:02 PM
GE Blades broke due to corrosion Wheels Garbage Disposer Repair 0 01-25-2008 07:20 PM
Toilet - Broke off intake valve Asystole General Talk 1 01-15-2008 05:25 PM
Dishwasher Door Handle Broke drobins Dishwasher Repair 6 01-15-2008 04:04 PM
control knob broke off jugular5 Refrigerator & Freezer Repair 0 08-14-2007 01:04 PM
