Discuss
auto teacher
 in
Washer Repair
My wife was using this washer, it took water in than just stopped working, the door stays locked but there
Appliance Repair Forum > Appliance Repair Help > Washer Repair » auto teacher
  #1 (permalink)
Old 01-21-2010, 02:57 PM
Junior Member
jbalaban is on a distinguished road
Default auto teacher
Model Number: 110-46462500   Brand: Kenmore   Age: 1 - 5 years
the door stays locked but there is no progress in cycles.
power ok
Cycle circiut breaker and it will take in more water and you can select spin and drain and it will pump water out but will not spin
Removed power for 5 min. to reset controls still no change
I do not hear any motor activation after load was put back in and washer refilled.
It will only let water in only after power is removed by cycling breaker
I am not sure where to start
The washer doesn't seem to be advancing to the next cycle.
I need help on where to start or a repair manual so I can begin to diagnose.
Help please
Ads By Google
Related Models
Kenmore 110.0  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.088732791  WASHER/DRYER LAUNDRY SYSTEM
Kenmore 110.1  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.10202000  COMPACT WASHER
Kenmore 110.10202001  WASHER
Kenmore 110.10502990  AUTOMATIC WASHER
Kenmore 110.10502991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.10852990  AUTOMATIC WASHER
Kenmore 110.10852991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12202100  WASHER
Kenmore 110.12502100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12852100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.13202200  WASHER
Kenmore 110.13212200  AUTOMATIC WASHER
Kenmore 110.14212200  AUTOMATIC WASHER
Kenmore 110.16101690  AUTOMATIC WASHER
Kenmore 110.16101691  AUTOMATIC WASHER
Kenmore 110.16202690  WASHER
Sears 110.16202691  AUTOMATIC WASHER
Kenmore 110.16502690  WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.16512690  WASHER
Kenmore 110.18202790  AUTOMATIC WASHER
Kenmore 110.18522790  AUTOMATIC WASHER
Kenmore 110.18522791  AUTOMATIC WASHER
Kenmore 110.18532790  AUTOMATIC WASHER
Kenmore 110.18542891  AUTOMATIC WASHER
Kenmore 110.18609890  AUTOMATIC WASHER
Kenmore 110.18702790  AUTOMATIC WASHER
Kenmore 110.18702791  AUTOMATIC WASHER
Kenmore 110.19101990  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101991  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101992  WASHER
Kenmore 110.19202200  AUTOMATIC WASHER-GALAXY
Kenmore 110.19422200  AUTOMATIC WASHER-GALAXY
Kenmore 110.20052991  WASHER
Kenmore 110.20052992  WASHER
Kenmore 110.20052993  AUTOMATIC WASHER
Kenmore 110.20056993  AUTOMATIC WASHER
Kenmore 110.20112000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.2011200A  WASHER
Kenmore 110.20132000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20132001  WASHER
Kenmore 110.20172000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20172001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.20272000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20272001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
  #2 (permalink)
Old 01-22-2010, 12:06 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
There should be a tech sheet inside the lower access panel (or under the top) which will take you through some troubleshooting.
Here is a service manual for your Whirlpool made washer.
https://secured.whirlpool.com/Servic...LE/8178558.pdf
__________________
  #3 (permalink)
Old 01-22-2010, 02:36 PM
Junior Member
Default
I can not seem to open the link for the manual, is there another way to the link?
this washer is a front loader and I have not found any papers but I will look again later this weekend when I get time
Thank I'll keep you posted
  #4 (permalink)
Old 01-22-2010, 04:23 PM
Senior Expert
APP Volunteer
Default
See if this will get you to it.
https://secured.whirlpool.com/Servic...a?OpenDocument
Click on the download and leave the mouse on the spot. It may take a while.
__________________
  #5 (permalink)
Old 01-23-2010, 06:53 PM
Junior Member
Default
Thank you
I found the manual inside the bottom cover
I tried the diagnostic and I believe I have a code F20
pressure switch or pressure problem
It also stated to push cancel twice to stark pump for 3 min.
pump never started so we removed the trap and about 1 quart
I tried to open the manual site again and it still does not open
I went to sears site and could not find a pressure switch or location
By the discription it sounds like it is in the drum or water inlet lines
I searched this site and it doesn't reconize the mod. #
Maybe you can help me with that so I rechecked the # 110.46462500
I plan to spend some time with the unit tomorrow I'll check in the afternoon.
  #6 (permalink)
Old 01-24-2010, 06:55 AM
Senior Expert
APP Volunteer
Default
Whirlpool has had some problems with their site recently, so that may be what you are experiencing.
If you go to the Sears parts site and use your model number without any dashes or dots you should get to an exploded view of your machine.
I got to this site this morning, so try this link again.
__________________
  #7 (permalink)
Old 01-24-2010, 01:44 PM
Junior Member
Default
I was on the sears site with the mod# last night and searched the pressure switch
It pulled up switches with no discription or location
  #8 (permalink)
Old 01-24-2010, 04:46 PM
Senior Expert
APP Volunteer
Default
Click on that link. It will say done and look like nothing is happening but let the computer alone for a while and the manual should come up.
You can access the switch by taking off the top.
__________________
  #9 (permalink)
Old 01-25-2010, 03:14 PM
Junior Member
Default codes
ok I think I'm figuring this thing out
The only thing that I seem to get to work is what is called service history mode & diagonstic test I get 2 codes
F/01 eeprom error ccu board
F 20 no water pressure dected
At this time I have nothing operating except the door lock
I have checked the water hoses and screens all ok
I removed the back and I beleive I have located the pressure switch and wiring and hose seems to be intact
I'm just about to order a electronic control from sears because I can not seem to find it on this site it also doesn't reconize the model # 110.46462500
Do you think I'm doing the right thing sears wants $118.00 for a control
or should I start with the pressure switch
  #10 (permalink)
Old 01-25-2010, 04:11 PM
Senior Expert
APP Volunteer
Default
Boy I wish I knew. If you have a Whirlpool Tech visit your house (you have a Whirlpool Duet Sport sold under the Sears Kenmore brand name) the tech would bring a truck full of parts and switch them out until he or she found the right combination that fixed things.
If water is not entering the machine I would go with replacing the CCU. If it is, entering then the pressure switch may be a better choice.
Were you able to get the manual?
Good luck, let us know how it works out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
