Discuss
Water doesn't drain Completely
 in
Washer Repair
Hi Everybody, When my machine goes into the spin cycle the water drains very slowly and I have to run
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water doesn't drain Completely
  #1 (permalink)
Old 04-10-2008, 02:04 AM
Blues Blues is offline
Junior Member
Blues is on a distinguished road
Unhappy Water doesn't drain Completely
Model Number: LAT5005AAE   Brand: Maytag   Age: 5 - 10 years
Hi Everybody,
When my machine goes into the spin cycle the water drains very slowly and I have to run through the spin cycle several times to get the water out of the machine.
Could it be the filter? The pump turns and the tub spins well enough.
The belts are loose but if there was a problem with tension then it would not spin which it does well.
Any Ideas?
Blues
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 04-10-2008, 07:23 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Blues,
Remove the front panel and check for a foreign objects in the pump and/or in the drain hoses.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 04-10-2008, 11:32 PM
Junior Member
Default Gene Thank You but I need a bit of Help!
Dear Gene,
I need to know how to remove the front panel. I remember I had done so for a Whirlpool washer but I did is ass-backwards draining the water and the turning the waher on its side and working from the bottom.
I know you are probably laughing right now. But removing the panel sounds so much simplier and easier.
Thank You Again,
Blues
  #4 (permalink)
Old 04-11-2008, 12:00 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the two screws on the bottom of the front panel. Grab the panel from the bottom and pull it up to release it from the top retainers. Now it's all yours.
Here are the break down diagrams for the Maytag washer Model LAT5005AAE
__________________
  #5 (permalink)
Old 04-11-2008, 09:19 AM
Junior Member
Smile Gene, My Hats Off to You Again, Thanks!
Gene,
Thank You Sir! I will be preforming surgery on the washer this evening once I'm finished working. Sometimes just a few words can save a person a lot of trouble and this is the case here.
Very Best Regards,
Blues
  #6 (permalink)
Old 04-11-2008, 04:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Blues,
I'm glad to hear it! Keep me updated, please.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune won't extract water completely letsal Dishwasher Repair 3 05-19-2008 01:23 PM
Will not drain water hagop Dishwasher Repair 9 05-13-2008 09:51 PM
Water wont drain shocks Washer Repair 0 03-07-2008 04:06 PM
Dishwasher doesn't drain completely melindac Dishwasher Repair 7 12-06-2007 04:35 PM
dishwasher won't drain completely ynot Dishwasher Repair 1 10-24-2007 11:11 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
