How do I remove the washer pump direct drive? I have removed the 2 clips. Does this unit slip off?
Yes it does, but if the pump has been leaking it can "weld" itself onto the motor shaft from rust and is difficult to pull off. Keep at it, it will come, but be careful.
you were right, I fixed it in 10 minutes. Thank you for your help. R. Reeves
