Bought a used Inglis (whirlpool) top load washer and when I got it home and started to use it it makes a rapid loud knocking sound and the agitater only goes about 1/4 turn clockwise at each knock, does not go back and forth. If I try to hold the agitater it will sometimes want to go back and forth but as soon as I let go it only rotates 1/4 turn clockwise. I assume the transmission is broken? Any way to tell how old this machine may be? The guy claimed only about 3 1/2 years old. The serial number is not legible anymore. Thanks Gary
A lot of times with used washer a problem like yours occurs because the tub is not secured during transporation. As a result, the suspension springs may be sprung, or the machine may not be sitting correctly on its base. You may also have a problem with the agitator cams, or "dogs" which cause the agitator to move when the motor turns. And, unfortunately, you may have a transmission problem. The first thing I would do is try the machine in spin mode. If it spins ok, your transmission may be ok. I would then pull the agitator and check the dogs, and also take off the cabinet and check the suspension plate, pads and springs. Replacing the springs is a good idea since you cannot determine a problem on a visual inspection. Here is a service manual that will show you how to get into the machine. https://secured.whirlpoo...2007475cb/$FILE/L-55.pdf
I took the washer back to the guy I got it from. It will now be his problem. Thanks for all you help and have a great day.
Gary
