Discuss
washer won't spin
 in
Washer Repair
I have a maytag washer everything work but when in spin cicle ,drains good but won't spin, can you help
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't spin
  #1 (permalink)
Old 01-19-2010, 01:18 PM
Junior Member
cesarbazan is on a distinguished road
Unhappy washer won't spin
Model Number: mav2755aww   Brand: Maytag   Age: 1 - 5 years
I have a maytag washer everything work but when in spin cicle ,drains good but won't spin, can you help me with this problem
Ricky
Ads By Google
Related Models
Maytag MAV2755AWW Washer - Top Loading
Maytag MAV2757AWW Washer - Top Loading
Maytag MAV275SAWW Washer - Top Loading
Maytag MAV308DAWW Washer - Top Loading
International MAV3350AGW Washer - Top Loading
Maytag MAV3757AWW Washer - Top Loading
Maytag MAV3758AWW Washer - Top Loading
Maytag MAV3855AGW Washer - Top Loading
Maytag MAV3855AKW Washer - Top Loading
Maytag MAV3855AWW Washer - Top Loading
Maytag MAV385SAWW Washer - Top Loading
Maytag MAV3905AWW Washer - Top Loading
Maytag MAV3955EWW Washer - Top Loading
Maytag MAV4057AWA Washer, Atlantis
Maytag MAV4057AWQ Washer, Atlantis
Maytag MAV4057AWW Washer, Atlantis
Maytag MAV408DAWK Washer - Top Loading
Maytag MAV408DAWW Washer - Top Loading
Maytag MAV4500AWW Washer, Atlantis
Maytag MAV4755AWW Washer - Top Loading
Maytag MAV4757AWW Washer - Top Loading
Maytag MAV4758AWW Washer - Top Loading
Maytag MAV5000AWQ Washer, Atlantis
Maytag MAV5000AWW Washer, Atlantis
Maytag MAV5057AWQ Washer, Atlantis
Maytag MAV5057AWW Washer, Atlantis
Maytag MAV551EEWW Washer - Top Loading
Maytag MAV5758EWW Washer - Top Loading
Maytag MAV5920AGW Washer - Top Loading
Maytag MAV5920EWK Washer - Top Loading
Maytag MAV5920EWW Washer - Top Loading
Maytag MAV5960AWW Washer, Atlantis
Maytag MAV6000AWQ Washer, Atlantis
Maytag MAV6000AWW Washer, Atlantis
Maytag MAV6057AWQ Washer, Atlantis
Maytag MAV6057AWW Washer, Atlantis
Maytag MAV6200AWQ Washer, Atlantis
Maytag MAV6200AWW Washer, Atlantis
Maytag MAV6250AWQ Washer, Atlantis
Maytag MAV6250AWW Washer, Atlantis
Maytag MAV6257AWQ Washer, Atlantis
Maytag MAV6257AWW Washer, Atlantis
Maytag MAV6260AWW Washer, Atlantis
International MAV6300AGW Washer - Top Loading
Maytag MAV6300AWQ Washer, Atlantis
Maytag MAV6300AWW Washer, Atlantis
International MAV6300BGW Washer - Top Loading
International MAV6300CGW Washer - Top Loading
Maytag MAV6357AWW Washer, Atlantis
Maytag MAV6358AWW Washer, Atlantis
Maytag MAV6451AGW Washer, Atlantis
Maytag MAV6451AWQ Washer, Atlantis
Maytag MAV6451AWW Washer, Atlantis
Maytag MAV6457AWW Washer, Atlantis
Maytag MAV6458AWW Washer, Atlantis
Maytag MAV6548AWQ Washer, Atlantis
Maytag MAV6548AWW Washer, Atlantis
Maytag MAV6601AWQ Washer, Atlantis
Maytag MAV6601AWW Washer, Atlantis
Maytag MAV6650AWW Washer, Atlantis
Maytag MAV7000AWQ Washer, Atlantis
Maytag MAV7000AWW Washer, Atlantis
Maytag MAV7057AWQ Washer, Atlantis
Maytag MAV7057AWW Washer, Atlantis
Maytag MAV7200AWQ Washer, Atlantis
Maytag MAV7200AWW Washer, Atlantis
Maytag MAV7257AWQ Washer, Atlantis
Maytag MAV7257AWW Washer, Atlantis
Maytag MAV7258AWQ Washer, Atlantis
Maytag MAV7258AWW Washer, Atlantis
Maytag MAV7260AWW Washer, Atlantis
Maytag MAV7260BWW Washer, Atlantis
Maytag MAV7357AWQ Washer, Atlantis
Maytag MAV7357AWW Washer, Atlantis
Maytag MAV7358AWQ Washer, Atlantis
Maytag MAV7358AWW Washer, Atlantis
Maytag MAV7450AWQ Washer, Atlantis
Maytag MAV7450AWW Washer, Atlantis
Maytag MAV7501EWW Washer, Atlantis
Maytag MAV7504EWW Washer, Atlantis
Maytag MAV7550AWQ Washer, Atlantis
Maytag MAV7550AWW Washer, Atlantis
Maytag MAV7551AWQ Washer, Atlantis
Maytag MAV7551AWW Washer, Atlantis
Maytag MAV7557EWQ Washer, Atlantis
Maytag MAV7557EWW Washer, Atlantis
Maytag MAV7580EWQ Washer, Atlantis
Maytag MAV7580EWW Washer, Atlantis
International MAV7600ACQ Washer - Top Loading
International MAV7600AGW Washer - Top Loading
Maytag MAV7600AWQ Washer, Atlantis
Maytag MAV7600AWW Washer, Atlantis
International MAV7600BGW Washer - Top Loading
International MAV7600CGW Washer - Top Loading
Maytag MAV7650AWQ Washer, Atlantis
Maytag MAV7650AWW Washer, Atlantis
Maytag MAV7657EWQ Washer, Atlantis
Maytag MAV7657EWW Washer, Atlantis
Maytag MAV7700AWQ Washer, Atlantis
Maytag MAV7700AWW Washer, Atlantis
International MAV7750AGW Washer - Top Loading
International MAV7750BGW Washer - Top Loading
International MAV7750CGW Washer - Top Loading
Maytag MAV7757AWQ Washer, Atlantis
Maytag MAV7757AWW Washer, Atlantis
Maytag MAV8000AWQ Washer, Atlantis
Maytag MAV8000AWW Washer, Atlantis
Maytag MAV8057AWQ Washer, Atlantis
Maytag MAV8057AWW Washer, Atlantis
Maytag MAV8260AWQ Washer, Atlantis
Maytag MAV8260AWW Washer, Atlantis
Maytag MAV8500AWA Washer, Atlantis
Maytag MAV8500AWQ Washer, Atlantis
Maytag MAV8500AWW Washer, Atlantis
Maytag MAV8551AWQ Washer, Atlantis
Maytag MAV8551AWW Washer, Atlantis
Maytag MAV8557AWQ Washer, Atlantis
Maytag MAV8557AWW Washer, Atlantis
Maytag MAV8600AWQ Washer, Atlantis
Maytag MAV8600AWW Washer, Atlantis
  #2 (permalink)
Old 01-20-2010, 04:24 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Does the motor run in spin?
__________________
  #3 (permalink)
Old 01-20-2010, 04:44 AM
Junior Member
Default
Quote:
yes the motor does run in spin I could see the motor and belt moving the trasmission and drum looks like wants to start moving but sometimes spin very slow or sometimes stuck.
  #4 (permalink)
Old 01-20-2010, 05:42 AM
Senior Expert
APP Volunteer
Default
Remove the belt and turn the tranny pulley in the spin direction. Brakes should release and tranny start to turn. If not, you have a worn thrust washer. You will need to buy the pulley and thrust washer kit and follow the directions, am not familiar with this repair, might want to re-post for more info. Also, sometimes if the housing gets wet from a leak, the brakes will stick. Sometimes if you tap on the brake housing while turning, they will release.
__________________
  #5 (permalink)
Old 01-20-2010, 07:37 AM
Junior Member
Default
Thank you
I,ll do that. But I the washer agitates good also I saw the pulley spining either in agitation or spin cicles.
Ricky
  #6 (permalink)
Old 01-26-2010, 12:07 AM
Junior Member
Default My washer won't spin
Quote:
Originally Posted by cesarbazan View Post
Thank you
Ricky
I removed the belt and pulley turns free I did run the washer on spin cicle
and started to spin but slow,after that i did run the washer on spin
cicle several times and was agitating like it in agitation cicle
Ricky
  #7 (permalink)
Old 01-26-2010, 01:40 AM
Senior Expert
APP Volunteer
Default
You might have a worn snubber if you see white shavings on the bottom of the washer.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer won't spin on rinse cycle or high spin bry21317 Washer Repair 10 05-24-2011 12:25 PM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
whirlpool washer won't spin manually or spin boniam Washer Repair 15 06-29-2008 07:19 AM
